    Page 2 of 2 FirstFirst 1 2
    Results 21 to 30 of 30
    Thread: McLeod 5 speed
    1. #21
      Dec 2009
      Oh man, I was so excited when I read that, but after checking the website I see they've dropped the torque rating to 500ft/lbs:
      http://www.mcleodracing.com/index.ph...nsmission.html
      That's tko600 money which is nice, but I was really hoping for a stronger package.
    2. #22
      Mar 2015
      San Rafael Ca.
      McLeod 5 speed
      I'll keep you posted. I really don't want to butcher my floor boards and I'm running a 427 mark IV with 3:73. I'll put it to the test. Autocross is my focal usage and weekend bruiser. I've heard they dropped the rating to be conservative.
    3. #23
      Feb 2012
      Central NY
      Do you know the gear ratio split? I found 1st gear ratio and overdrive, but nothing about 2, 3, and I'm assuming 4th is 1:1.
    4. #24
      Jun 2009
      Massachusetts
      Quote Originally Posted by Streetbu View Post
      I asked the question on their site and within 1/2 hr got this response (now that's customer service)
      "Thank You for your interest in McLeod Racing.
      The McLeod Racing Muscle Car 5 Speed is a Muncie Style replacement, based on a smaller more compact case design so there will be little to no tunnel modification.
      The 5 speed comes with 8620 forged gear sets with the following gear ratio. 1st 2.95 2nd 1.99 3rd 1.34 4th 1.00 5th .63 along with a 32 spline output shaft.
      The same as a turbo 400 or a super t-10.
      The transmission does not fit the factory cross member on any of the GM platforms, so that is one thing you'll need to figure out.
      The part number for the GM is 512957 and costs $2795.00 plus shipping.
      See attached file for the dimensions of the transmission. Weight comes in around 85 lbs dry.
      Kind Regards,
      Billy Mieczkowski
      Technical Sales
      Mcleod Racing
      1600 Sierra Madre Circle
      Placentia, Ca 92870
      [email protected]
      tel:714 630 2764 Ext 223
      Larry Nirenberg
      '23 Mercedes S500
      '23 Corvette Z06
      ’62 Chevy C10
    5. #25
      Feb 2012
      Central NY
      Thanks!
    6. #26
      Jun 2010
      Deployed
      Little to no cutting? That means expect to cut...that's a lot of money when you compare it to the tko 600 with better gear ratios and a higher torque rating.
      tko has a larger supporting market today as you can get a crossmember for it.
    7. #27
      Mar 2015
      San Rafael Ca.
      McLeod 5 speed
      If anyone comes up with a remedy for the cross member I am all ears. Running into that dilemma now.
    8. #28
      Jun 2010
      Deployed
      Quote Originally Posted by btroedel View Post
      Contact Bowler Transmission. They likely don't have one for the McLeod specifically, but one that might work.
    9. #29
      Mar 2015
      Yes I have one in my 57 Chevy. They sent it with Red Line synthetic oil (2 quarts). It is just now breaking in and is stiff to shift. I was never a fan of Red Roberts shifter and that is what is on it. The shifter does not return from the first/second gate so it is sometimes hard to find third. So far so good. Steve
    10. #30
      May 2015
      Island Lake, IL
      Any users or updates on this?
