    Results 1 to 9 of 9
    Thread: Wire Adapter?
      Crown Point, Indiana
      Wire Adapter?
      I am running into a problem while mocking up my new wiring harness I ran into a snag. This is the A/C wire the 2 prong is coming from the harness the 1 wire (green) is coming from the Sanden compressor. Do they make an adapter for this I will be running a VA system in the future.
      Jun 2005
      Lynnwood Wa.
      Sorry I meant how do I connect these 2 wires into one. What are the 2 coming from the computer positive and one ground? So the one on the compressor is positive and I just need to run a wire to the compressor to ground?
      Phoenix
      The two from the computer are power and ground, your Sanden compressor should ground through it's attachment to the engine block and not need a ground wire.
      On my 2005 GTO harness it's a green wire for power and a black w/red stripe for ground to the compressor.
      Erik
      https://www.pro-touring.com/showthre...without-a-name
      Camaro LS2, T56, 12 bolt, C6 Z06 brakes, Rushforth Super Spokes, ATS Spindles
      2006 Chevy Trailblazer SS
      Mountain Springs, Texas
      The Vintage Air harness will supply the power for your compressor. The only wire from the factory harness you need should is the AC sense wire which will tell the ECM to turn on the fans when the compressor is running. You will need to figure out which wire is the AC sense wire and connect the three wires together (VA power, compressor power and AC sense). Who reworked your harness?
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Bought the harness from Speartech. John made it per my application.
      Kingsport, TN. 30 min. from Bristol and 90 min. from Pigeon Forge, TN.
      If you can find a factory diagram to find out which wire in the factory harness is the power supply and connect it then you'll be in business.
      The VA harness needs to supply power to the compressor, not the ECM. Your VA will not work otherwise. I think you should give Speartech a call to clarify what those two wires are connected to and also ask him about the AC request signal.
      69LAnd
      well the ecm for sure doesnt turn on the compressor so that connector its just ran with the harness but im sure the other end is left on the wires that should go through the firewall im sure theres a tag that says AC ON or very similar,so from your vintageair theres a clutch wire thats 12v+ when on and that should go attached to the ac wire by the other end of your harness and then that plug could be converted to a single wire plug as the sanden compressor its already grounded to the compressor body
      Rick M.
      hMMMMMMsss....
      1969 Camaro real RS SS DSE LS3 6M TWiiN TURBO in the make!(taking forever!!)..any donations apreciated hehe
