      Jun 2010
      Which Power steering hoses do I use???
      Im using the grand cherokee steering box conversion and trying to use ls truck front pulley accessory.
      2003 Silverado RCSB with Procharger
      1967 GTO LQ4/muncie project
      Pensacola, FL
      Probably easiest to have some made. Use some old fuel or vacuum line to mock up the routing and bring them with you. Also, If you have the fittings from the cherokee box & truck pump it would simplify things to get the correct fittings. Not sure if the flow rate on the truck pump is a good match for the cherokee box, but its probably ok. I have no experience with either.
      Scott
      Jan 2010
      Elk River, MN
      Why not just make up some hoses using Aeroquip high pressure hose and fittings?
      -matt
      Melbourne, FL
      Quote Originally Posted by monteboy84 View Post
      -matt
      That's what I did....
      http://www.aeroquip.cc/aeroquippower...rehosefbg.aspx
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Jun 2009
      Quote Originally Posted by 67 455 Bird ragtop View Post
      Does anyone offer a hose like this in black? All the ps hoses I've found are blue or stainless and that won't match anything I'm doing.
      Nothern California
      Hey Jwalk try hose and fitting in West Sac
      Hose & Fittings Etc
      1811 Enterprise Blvd, West Sacramento, CA 95691 » Map
      (916) 372-3888
      Guy S.
      68 Camaro LS1, T56, Forgeline WC3
      69 El Camino BBC 4spd A/C Cruise SOLD
      2012 Dodge Crewcab Diesel 4x4
      Jun 2009
      Quote Originally Posted by DEIGuy38 View Post
      Hose & Fittings Etc
      (916) 372-3888
      Thanks, I'll check them out!
      May 2008
      Are you using the pump valving from the pump that came with the cherokee box??
      Im doing this conversion now,,,have the valving from a grand cherokee in my old pump,,,borgeson makes a set of hoses (I think $68 at summit),,comes in black,,,and also with the adapter pieces that need to be inserted into the box fitting!!!
