    Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
    Results 61 to 80 of 169
      May 2007
      Mooresville, Indiana
      There is a good chance that the pickup "sock" in the fuel tank is clogged up. Best bet would be a new pickup/sending unit, but you could probably just remove the gummed up sock to see if it runs. Just a temporary fix for sure.
      Feb 2009
      Long island, New York
      check out ss396.com i built half my car from their parts. its all good quality stuff but at a really affordable price even for us college guys! their sending units are like $34 or so, they have everything for our cars. dont give up you will figure it out. -Dom
      Dom Buffa
      Jun 2009
      Central FL
      It's not the sending unit. It's still the damn pump. The NEW pump isn't pumping.
      Damn, this is killing me. What can cause the pump to not work?
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Feb 2009
      push rod too short maybe?? is the pump same spec as the old one? maybe the lobe on the came is worn down and not compressing the spring inside the pump enough to make it pump. but like always its probably something stupid that is overlooked. triple check everything.-Dom
      Dom Buffa
      Scottsdale, AZ
      Hey! You're on Arfcom right?
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Jun 2009
      Central FL
      Quote Originally Posted by Cdog View Post
      OPSEC.
      Quote Originally Posted by 69projectKAOS View Post
      Yeah, I am. Taking the pump back off today, inspecting everything. I knew that pump swap was too easy...
      Dan
      1968 Camaro v2
      Scottsdale, AZ
      Quote Originally Posted by Vicinity View Post
      OPSEC.
      LOL! Cool Story Bro!
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Aug 2008
      NW WA State
      OPSEC.
      Thought I recognized the name/car....
      Jun 2009
      Central FL
      Quote Originally Posted by sixgunsblazing View Post
      Wow, a lot of you guys on here... Two hobbies that go together great, right?
      Dan
      1968 Camaro v2
      Jun 2009
      Central FL
      Oh my God. I pulled the pushrod out because I couldn't move it. It's bent, and not just a little. It's a massive bend.
      Here's where it bent.
      What could have possibly caused this? This is one thick pushrod...
      Dan
      1968 Camaro v2
      Feb 2009
      i told you it is always something overlooked! lol happens to me everytime. glad to see that you figured it out, and the car looks great all you need is a drop and it will be sweet! -Dom
      Dom Buffa
      Jun 2009
      Central FL
      Ok, I forgot to pull out the front side bolt that holds the oil in. Whoops. But I did get this awesome shot in the shop.
      Dan
      1968 Camaro v2
      Feb 2011
      dallas, tx
      tires are facing the wrong direction
      Jun 2009
      Central FL
      Quote Originally Posted by icemanrd19 View Post
      Yeah, I know. Since the car isn't driving anywhere, I haven't been too worried about it.
      Dan
      1968 Camaro v2
      Jun 2009
      Central FL
      Debating a 2 vs 3 inch drop. The bottom of the fender is exact 4 inches off the very top of the tire, I don't want it riding the top of the tire. Hmm... decisions, decisions....
      Dan
      1968 Camaro v2
      Jun 2009
      Central FL
      She just ate another pushrod. Exactly the same way, I'm thinking it's not a coincidence.
      Dan
      1968 Camaro v2
      Jan 2010
      Elk River, MN
      Have you run this motor before? If you have, what changes have you made since the last time it was run?
      There are really only a few common things that will cause pushrods to bend like that without abuse:
      1. Valvesprings coil-binding (Also check the valvespring internal dampers, they can bind too)
      2. Valvespring keepers bottoming out on valve guides
      3. Valve/Piston Interference - Though, this will typically bend the valve rather than the pushrod.
      What heads are on your motor?
      -matt
      Jun 2009
      Central FL
      Quote Originally Posted by monteboy84 View Post
      -matt
      It's a fuel pump push rod. And no, I haven't ran the motor before, but the car was started by directly putting gas into the carb. The fuel pump may or may not have worked when I got the motor.
      Dan
      1968 Camaro v2
      Jan 2010
      Elk River, MN
      Oh shoot, I'm a putz, should have looked at the pics closer I guess.
      I'd just put a different pump on, or try to see if maybe the pump arm is somehow bottoming out inside the block.
      -matt
      San Antonio, Tx
      try this
      http://rarecorvettes.com/RARE/FuelPump.html
      seeing the picture you posted on team camaro it sounds like this could be your issue.
      Instagram: CamaroAJ
