    Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
    Results 41 to 60 of 169
    1. #41
      Jun 2009
      Central FL
      Quote Originally Posted by 69projectKAOS View Post
      i actually had a older style msd one laying around, so i bought a msd overhaul kit(rotor,cap,Solenoid etc.) from jegs.com and just used that. -Dom
      Ah, I was gonna go with MSD, but they were like $140 + shipping.
      I saw the Jegs one on sale, but read some really bad reviews. The Eastwood one I bought it supposed to be an OE replacement.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
    2. #42
      Feb 2009
      Long island, New York
      funny you said that i had a eastwood dist as well! it worked great you wont be disappointed. i bought a msd ignition box so i went with the msd distributor to keep it all the same.-Dom
      Dom Buffa
    3. #43
      Jun 2009
      Central FL
      Gotcha. Good to know. I'm sitting here at the computer waiting for the FedEx truck now!
      Dan
      1968 Camaro v2
    4. #44
      Jun 2009
      Central FL
      We're in business.
      Dan
      1968 Camaro v2
    5. #45
      Templeton, CA
      You have to love it when the delivery truck gets there! I should have a delivery tomorrow!
      Keep the pics coming.
      Robert
      My sloooow build thread...https://www.pro-touring.com/showthre...hlight=Orngasm
      "If happiness is in your destiny, you need not be in a hurry."
      If I can only convince myself of this!
    6. #46
      Jun 2009
      Central FL
      Damn, I know this isn't right...
      All the ways of switching a distributor I saw on Youtube were essentially taking the top end of the motor apart. I didn't want to do that. I pointed the rotor toward the #1 cylinder (front most driverside) and pulled the distributor.
      I put the new one in, the EXACT SAME SPOT and now I can't get it to seat all the way in. Any tips?
      Dan
      1968 Camaro v2
    7. #47
      Maryville, TN
      What size wheels are your front wheels and where did you get them? Mine are supposedly 17 x 9.5s, but holy crap... they're not even close to fitting. I bought the most backspacing I could at the time... can't remember now where they came from though. I'm having the exact same clearance problems you are though.
      Dan
      A.K.A: That bald guy
      Find me on Facebook or my personal website.
      - 67 Camaro: Current Project Car
    8. #48
      Jun 2009
      Central FL
      Quote Originally Posted by 67SSDan View Post
      Dan
      They're OEM 4th gen SS wheels (ZR1), so 17x9.5". You need to space it out 1.75" from the hub, otherwise it will rub on the steering linkage.
      Dan
      1968 Camaro v2
    9. #49
      San Antonio, Tx
      looks like its not in all the way because of the oil pump. turn the engine over my hand and see if it drops down all the way. it should once the pump shaft lines up.
      Instagram: CamaroAJ
    10. #50
      Jun 2009
      Central FL
      Quote Originally Posted by CamaroAJ View Post
      That's what a guy on camaros.net said, I'm almost positive that's what it is. I'll be at the shop all day tomorrow, so hopefully I'll have it setup and ready to run!!
      Dan
      1968 Camaro v2
    11. #51
      Feb 2009
      ++1 had that happen a couple times, just turn it over by hand and it drops down. keep us posted with updates!.-Dom
      Dom Buffa
    12. #52
      Oct 2007
      Shawnee, KS
      Do you have a long common screw driver? I usually just turn the pump shaft slot with the screw driver to match the distributor.
      Shannon
      67 Camaro - Finally getting to BUILD it.
      Camaro Build -> HERE
      Our Drag boat blog and videos HERE
    13. #53
      Jun 2009
      Central FL
      Got it!
      The old dist was at 5:30, this one needed to be at 4:30~.
      I guess Eastwood makes the ultimate HEI unit, no notching required.
      I need to connect the 12v wire and the coil wire, then off to try and start (again). But first, I gotta head into work. This is going to be a LONG day.
      Dan
      1968 Camaro v2
    14. #54
      Long Beach, Ca
      Holy plug wires bat mite! Glad to hear it went in smoothly. Now get home and fire it up!
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
    15. #55
      Jun 2009
      Central FL
      Quote Originally Posted by Nessumsar View Post
      Yeah, the local parts shop didn't have plug wire holders in stock. :(
      I got the car started, but I don't have a video, because theres no fuel being pumped to the carb. The plunger on the carb is dryrotted out. I think I might need a new carb. I got a method an old mechanic friend of mine suggested I try before I spend the money. So right now it's running on gas poured into the carb and starter fluid.
      But, as soon as that's done, she'll be running!
      I hope.
      Dan
      1968 Camaro v2
    16. #56
      Jun 2009
      Central FL
      I tried that method I spoke of earlier, it's a no go. I think the carb was just sitting outside for so long theres nothing for the gas to soak into to give me a little better seal on the gaskets.
      So, I guess it's time for a new carb. I've been looking at the 725cfm Demon Jrs, anyone have any experience with them? I've been recommended to avoid Holley's because they have to be rebuilt more often.
      Dan
      1968 Camaro v2
    17. #57
      Jun 2009
      Central FL
      Ugh, had the Qjet rebuilt, installed it, got nothing. Decided to check to see if any fuel was flowing. It was not. fuel pump is dead.
      Any reason to upgrade to an electric fuel pump? or just stay mech?
      Dan
      1968 Camaro v2
    18. #58
      Feb 2009
      if you go electric then you have to block off the block etc, and then make sure you have a fuel press. regulator because you dont want to push more fuel than needed. i would just stay with a stock setup until you start doing more work to the motor etc. and it will be cheaper so you can get it on the road and enjoy it.-Dom
      Dom Buffa
    19. #59
      Jun 2009
      Central FL
      Yeah, I opted for the mech pump. But I'm still not getting any fuel. Gonna drop the tank, now.
      Dan
      1968 Camaro v2
    20. #60
      May 2007
      Mooresville, Indiana
      There is a good chance that the pickup "sock" in the fuel tank is clogged up. Best bet would be a new pickup/sending unit, but you could probably just remove the gummed up sock to see if it runs. Just a temporary fix for sure.
