    Results 1 to 8 of 8
      Castro Valley, CA
      Drive by Wire Conversion Help
      I have been searching for the last hour and cant seem to find what I need. I ordered a new PSI harness with drive by wire so I can get rid of the ugly wire on the firewall.
      I know I need a new DBW throttle body and pedal and the box that goes between them.
      Question is where do I get it and does anyone have a part number that I can order from GM or get from a junkyard? Which pedal from what year/model car do I need?
      Please help
      John
      John S.
      68 "Bloodline" Camaro in assembly...
      Speedtech Sub, Alston G-Billet/Fab 9 rear, Ridetech coil overs, Moser axles, Fesler 19's, Lots of Anvil parts,Twin tubo LS3/T56, Carbon fiber manifold, and the list goes on and on..........
      Castro Valley, CA
      ok so after searching for 3 hours Im starting to think it is going to be a big PITA to do this and that my cable throttle is way cheaper.
      John S.
      Oct 2006
      Morristown, NJ
      Lokar makes drive by wire pedals now.
      http://www.lokar.com/product-pgs/new...e-by-wire.html
      1973 Camaro Type LT/RS
      http://www.apiem.com/camaro
      Dec 2009
      Carson City, NV
      Quote Originally Posted by amargari View Post
      Nice looking setup they have, anybody know if this will work with the Holley Dominator EFI?
      Feb 2010
      NE Arkansas
      Nice, does anyone know what the prices on those are going to be?
      Nov 2004
      Colorado
      From what I've found after researching this for my DBW conversion ff you are using a 12200411 PCM (which is the best choice for ony 24x setup) you have the choice of using the 97-04 corvette TAC module and pedal with the Corvette calibration or the 2000-2002 truck TAC and pedal with the truck calibration. The pedal, TAC and calibration can only be used as a set. The later truck stuff, 2003-2007 is not a good choice as you cannot use the passenger car throttle bodies like the 90mm LS2.
      Good luck finding a Corvette TAC module, for some reason they are scarce and GM dealers will only sell them if you have a VIN. flea-bay prices are in the $200 range when they pop up. Avoid any used pre 2000 TACs as they had problems.
      Truck TAC module GM#12574221
      Corvette TAC 12578953 or perhaps 19245405
      Corvette pedal 12565643
      Don't know the part #s for truck pedals, theres at least a couple variations of them depending on options.
      Later DBW setups integrate the TAC into the PCM. These setups require additional hardware for cruise control (if thats something you want)
      I am using the 411 PCM with Corvette TAC and pedal on my 540 BBC.
      John at Speartech had the pedal, harness, and TAC module for Vettes - he probably has ECM's too. Do some digging on LS1tech.com for how-to's on converting the throttle body or probably pick up an appropriate DBW throttle body.
      it's a lot of chump change if you just want to hide the throttle cable. Good luck.
      Feb 2010
      NE Arkansas
      FWIW I modified my truck pedal to fit my car by cutting off the arm and making my own in the correct lenght with a piece of 1/4" steel.
