    Page 2 of 2 FirstFirst 1 2
    Results 21 to 23 of 23
    1. #21
      One thing at a time, have you adjusted the timing yet?
    2. #22
      Aug 2008
      Houston, TX
      One more update for today...I reset the idle mixture screws from one at ~2 turns and the rest at 1/4 turn to all being an equal 3/8 out which made it idle a tad worse and run a bit less strong. Driving in a parking lot is still fairly difficult. The throttle is very touchy, eg. the slightest touch throws you into the back of your seat and makes the car buck. I can relieve this by being very gentle on the throttle and slipping the clutch. The car is also still lacking power and throttle response in the 1000-2500rpm range. Anything over that and it starts to clear up.
      68Formula: I upped the timing to 14-15 initial and 32-33 all in at 3000. It ran pretty good till i equalized all the mixture screws to 3/8 turn out.
      Jeff: I still need to rejet the carb and remove the jet extensions...I will do that most likely on Sunday.
      Lemme know what you guys think. Thanks again and have a happy New Year!
      Cheers!
      Matt
      Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
    3. #23
      NH
      Happy New Year!
      Matt,
      If closing down that mix screw to match the rest made the engine idle rough then that means to it's too lean.
      Open all mix screws evenly 1/8 to 1/4 turns at a time ti'll it smooths out.
      Post your airbleed sizes
      With your fastburn heads and using the MSD black 18 degree bushing you can go up to 16 initinal and 34 total no problem.
      Got any good underhood pics so I can see what you got going on?
