Results 1 to 20 of 23
Thread: Holley Tuning for E10
Hello Guys,
My engine has had intermittent running problems which seem to point to fuel delivery. The carburetor is a quickfuel 680cfm which should be set up just right for my engine (zz383). The timing is correct. I feel as if the recently mandatory E10 gasohol is the culprit.
I have read in a publication that when tuning for E10 one should:
"lower float levels 1/32 from original specifications increase main metering circuits’ fuel flow by 10 percent, increase idle jet diameter by 0.002 inch."
The publication is found HERE.
What do you think? The engine is low on power, is quite hard to get a consistent idle with the mixture screws, and just runs flat out STRANGE compared to a couple of years ago when straight gasoline could be purchased.
Thanks in advance for the assitance.
Cheers,
MattWho is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
