    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 44 of 44
    Thread: High vs low RPM
    1. #41
      Aug 2008
      Pgh, PA
      Quote Originally Posted by 79-TA View Post
      Maybe 500-600 would be an epic enough amount?
      I'm sorry, I haven't added much new to the conversation with this post, but does the 700 lb-ft figure grab anyone else as a bit excessive?
      Yes. I think it's going to be REAL hard to control 700lbs unless the chassis has a lot more money and time spent on it than the engine. JMHO. I'm still trying to figure out how to control the 600lbs I've got.
    2. #42
      USA
      McClaren used Aliminum Big-Block Chevys , and ran very well in the Can-Am Series in the late 60's/early 70's.
      Ferrari entered the 512( 5.0 liter V-12) and 712( 7.0 liter V-12 ) in the Can Am , but did not compete very well with the big bore American powerplants ..
      For a street-car , torque is king , whether you use a small block or big block to make it.
      Low RPM cruising saves engine wear and yields better gas mileage .
      On a race car , often times there are engine size limitations , and the higher RPM makes more horsepower for a given cubic inches.
      Jeff Tate
      U.S.A.
    3. #43
      Rustburg, Virginia
      Quote Originally Posted by JEFFTATE View Post
      Yup, engines are basically an air pump...the more air/fuel you can pump through them, the more power, and if cubes are limited, then you have no choice but to increase the revs to get more air/fuel through the n/a engine.
    4. #44
      Rockford Illinois
      It has always seemed to be that if you couldn't rev past 5250 RPM torque was all you could count on which made the big blocks feasable with taller rear gears to go forever in the old days and it is still the same today. The killer HP that a big block makes when you spin it up is exponential.
      I have trouble with 400 ft lb of torque staying planted in 1st and 2nd so that much power would take it to 3rd and 4th and that is very fast territory and you better have room if you plan to light them up, which will happen too easily with little pedal travel. I have a lot of experience to gain to be able to be in total control at the 3 digit speeds on a track where each lap is different because of all the factors involved. Brakes always change a little and stopping is where a lot is gained in time.
      I truly think that no matter what engine he puts in the car it will be as much as he expecting and more ! I hope he gets what he wants and likes it.
