    Results 1 to 9 of 9
      Aug 2008
      Houston, TX
      Deceleration Thump
      Hello,
      I just finished putting my 70 camaro together; tko600, new driveshaft, currie 9 inch, wilwood disc brakes all four corners...
      When I decelerate and push the brake pedal I hear and feel through the body a thump thump thump whenever the brakes are applied. It feels as if it is coming from the center of the car. The car stops very well and I cannot feel pulsing in the pedal.
      Any suggestions??
      Thanks guys,
      Matt
      Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
      May 2002
      Northern California
      get the car up on a lift and check for fresh rubbed metal. With the TKO I'm willing to guess its the front driveshaft u joint hitting the mid car floor brace.
      Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Ramona, Ca. San Diego area
      Check your u-joints, trans mount, engine mounts, and you u-bolts on your rear end.
      67 Camaro convertible (Jinx)
      Auburn, CA
      I had his same issue once on a 69 Camaro and it was one of the front leaf spring mounts. I had just bought the car because the former owner was tired of trying to find the problem.
      Tim Tracy
      Aug 2008
      Houston, TX
      Hey I checked the driveshaft; it is free of obstructions and all of the mounts are tight...how should I proceed now?
      PS how would I check the leaf spring mount?
      Matt
      hey Matt, did you ever find the problem?
      USA
      Is the transmission hitting the tunnel or floorboard ?
      Jeff Tate
      U.S.A.
      Apr 2004
      Cedar Rapids, IA
      Could the pinion angle be changing drasticly enough with the decelerationa and breaks to cause some sort of bind?
      Strap a video camera under the car and take a video of the thing while driving.
      u-joint
      Second on the u-joint. On deceleration the pinion with go downward and possibly change angle enough to bind a u-joint
