    Results 21 to 34 of 34
      Jul 2010
      Rancho Murieta
      93 S10 Suspension Help
      Hi Everyone,
      I'm new to the board so this is my first post. My friend actually introduced me to the site because he wanted to show me the Syborg. By the way, that truck is insane!
      Okay, onto my truck. Reg cab 93, 2wd 2.8 5sp. I started by putting DJM 2" drop springs in the front with stock replacement sensatracs (yes they actually have enough travel, the front rides great and now stays relatively flat with the 1 1/4" if i remember correctly sway bar from a junkyard blazer. I originally went with 3" blocks in the rear and a set of djm shocks to try and stiffen it up. I LOVED THIS SETUP! However, my truck had a lot of miles on it and my leafs started to squeak and grind and needed rebuilding. Instead of stock replacements, I opted for the Beltech 3" multi-pack drop springs. I went with these because I heard you will have bad axle wrap with the mono leafs. Well from day one I've HATED these springs, they ride extremely stiff and are very bouncy. Now I like a good firm ride and very little sway since I drive "somewhat aggressively," however this are simply bone jarring and the truck sat almost as tall as the stock springs with no blocks plus I still experienced plenty of axle wrap. Well, i've simply dealt with this problem for a few years now, I've added blocks to level the truck out, i've tried between 1" to 3", right now i'm running 3" to level it, that seems rediculous since the front only has 2" springs and these are supposedly 3" drop leafs. Adding the blocks has also caused more axle wrap (never did with stock leafs), i've also tried different shocks, I ordered a set of Beltech Shocks to try and counteract the bouncy ride. Made it worse so I went back to the DJM shocks but got a shorter version of it for more travel, still HARSH and bouncy. I'm sort of lost now, i've never heard of anyone else having these problems, in fact I see most people recommend beltechs when people are staying with leafs on the back of S10's. Now for a while now i've been considering going with the ZQ8 leaf springs, they are around 2" of drop and i've seen people add blocks with no problems, however they did have the anti hop shock. Is this my best route without spending too much money. I see these springs with low miles on ebay for $125 all the time. Any suggestions would be great, i'm soo sick of the horrible ride and my wife absolutely hates riding in my truck with me. I still had stock springs when we dated and she liked to back then! Sorry for the long post but I wanted to be thorough, any help is appreciated, i'm sure most of you have way more experience than I do with suspension. Thanks!
      Nick
