- Jan 2010
- Elk River, MN
- 676
Rear Swaybar - Endlinks to LCA's?
I'm in process on my Monte Carlo, trying to decide on some specifics of what I'd like to do with the suspension bits. One thing I'm up against, I want to run a rear swaybar, but not a factory one as they bolt between the LCA's and cause binding, far from ideal.
So, what I'm looking at, I have an F-body rear bar here with mounting hardware, where the bar bolts to clamps on the housing tubes, and the endlinks go to the chassis - on the F-body that is.
Now, on the G, everything fits great, except for that the ends of the swaybar line up almost perfectly (I need to measure the actual C-C distance to see) with the lower control arms. Now, what I'm considering here is simply attaching the endlinks of the swaybar to the control arms themselves. At first thought it seems like there should be some problem with doing this, but after some thinking, I don't see where it would cause any problem. In actuality, I think it may be better than running it to the chassis, since there is a possibility of bind in that kind of arrangement, if only under full-droop.
For reference, I'll be running Spohn LCA's with Del-Sphere bushings, which have a round body. Due to this I'll have to either modify the arms themselves with attached brackets, or develop some clamp-on brackets for attachment of the bar. But, that's not my concern at this point.
So, what say you? Any thoughts/criticism appreciated.
-mattMatt Peterson 84 Monte Carlo - Sold :( | 99 Corvette Racecar | 2001 Z06 Daily Driver
https://www.pro-touring.com/showthre...ng-Bertha-Back
http://ls1tech.com/forums/conversions-hybrids/1499192-84-monte-5-3-build.html
https://www.pro-touring.com/threads/...rvette-Racecar
