Results 41 to 60 of 108
- Jan 2010
- Elk River, MN
- 676
I've changed it slightly since these pictures, but basically what I did is get a Grade 8 socket head bolt the right length and run it the opposite direction of the bolts in the pictures, so the shear force is on the full diameter of the bolt, rather than on the minor diameter of the threads as it is in the pictures. I've got pictures of that which I still need to upload, I meant to get them on last night but got side-tracked with some things.
I know it's not ideal, and I plan to change it eventually, but not until I get some shorter shocks for it and complete my new rear suspension design. I've run similar mount arrangements on far more abusive applications with good results in the past.
-matt
Matt Peterson 84 Monte Carlo - Sold :( | 99 Corvette Racecar | 2001 Z06 Daily Driver
https://www.pro-touring.com/showthre...ng-Bertha-Back
http://ls1tech.com/forums/conversions-hybrids/1499192-84-monte-5-3-build.html
https://www.pro-touring.com/threads/...rvette-Racecar
07-14-2011 #2
- Jan 2010
- Elk River, MN
- 676
Pictures as promised:
The front end obviously hasn't been lowered here, this is on stock springs up front at this point.
New windshield from Safelite, the price was very reasonable and it's a nice quality piece. I installed it myself due to the restoration needed in the mounting flange area. Took a good bit of wire wheeling and naval jelly before primer and paint, but it came out pretty good. Windshield molding is obviously still off.
Sealed up some failed seam sealer with windshield urethane temporarily.
Much better back here now.
Front end is still jacked.
Naaasty. Swaybar bolt predictably snapped right off.
Somehow I missed getting pictures of installing the Savitske front end kit, so I'll have to get pictures later.
Thi begins my LS1 rear disc conversion, though I haven't rigged up the parking brake cables yet, so these pictures merely cover the bracket and caliper installation.
Yuck, good riddance.
Hacking off the upper part of the housing flange, I ended up pretty close to where the radius cut comes to a point on the flange.
-mattMatt Peterson 84 Monte Carlo - Sold :( | 99 Corvette Racecar | 2001 Z06 Daily Driver
07-14-2011 #3
- Jan 2010
- Elk River, MN
- 676
Ls1 rears all buttoned up, using C5 calipers.
07-14-2011 #4
- Jan 2010
- Elk River, MN
- 676
All cut, drilled and ready for assembly.
This shows my new shock bolt pretty well, still haven't gusseted the tubes though as the car hasn't been on the road yet.
07-14-2011 #5Nice work looks like its coming along real good! Ever think of painting your wheels black?
Havii Gonzalez, OC Calif.
68' MARO - UNDER FULL RESTO - LSX ect..
Used to be known as stilo
07-14-2011 #6
- Jan 2010
- Elk River, MN
- 676
Thanks stilo! Black has definitely crossed my mind, but some days I think gunmetal would look better, or bronze, and I've even considered white
I've basically decided to get it on the road first-thing and then try to decide, might put it up to a vote here and see what people think, I am terribly indecisive on things like that.
Though, the brakes will be done in Tungsten Gray Cerakote, which may make black the new leader for the wheels...
07-15-2011 #7
Pro-Touring Veteran
- Nov 2006
- Washington, MO
- 2,363
What are you using for the master, booster and prop valve? stock setup?
07-15-2011 #8
- Jan 2010
- Elk River, MN
- 676
Yeah it's all stock stuff currently, it has a pretty nice aluminum master that looks fairly modern so I've decided to leave it. I either have to gut the prop valve and add an adjustable one, or get an SSBC adjustable to bolt in place of my stocker, but that can wait until it's ready for the road. They work fine for rolling in and out of the shop but I'm sure they'll be wrong for street use.
-matt
ETA: I ordered FlexKore custom brake hoses from Kore3 for this, they really made the install a breeze and the price is hard to beat, comparable to any other set of braided lines out there. They also saved me from having to cut and re-flare the brake lines on my axle, which you'd have to do if you used the LS1 brake hoses.Matt Peterson 84 Monte Carlo - Sold :( | 99 Corvette Racecar | 2001 Z06 Daily Driver
07-18-2011 #9
Pro-Touring Veteran
- Nov 2006
- Washington, MO
- 2,363
07-25-2011 #10
- Jan 2010
- Elk River, MN
- 676
I've got an update on this. I drove the car about 150 miles this weekend and got a chance to give the brakes a real test on a back-road. After 3 or 4 stop-tests, I've got way too much rear brake, every time I eased onto brakes until lock-up, it was the rears locking up first. So, I need to put an adjustable proportioning valve in and gut my stock proportioning valve, I imagine you will need to do the same.
07-15-2011 #11
- Apr 2006
- MD
- 232
