    Page 2 of 2 FirstFirst 1 2
    Results 21 to 32 of 32
    Thread: Corner weights
    1. #21
      Greenwood, SC
      David,
      Is it EVER advantageous to add any ballast weight to the rear of the car to get closer to 50/50? I know it wouldn't be the case with Scot because he would have to add about 500 lbs, but would that EVER work?
      I'm just hypothesizing.... lol
      JC Scott
    2. #22
      Central CA USA
      I don't believe in adding rear weight to get a car closer to a 50-50 weight percentage. I do like to run with an almost full tank of gas when I autocross. Especially with cars that are having some wheel spin issues. The extra weight can help you get a little better rear traction, but adding a lot of rear weight is just making the car heavier and that isn't worth it.
    3. #23
      Sunny Florida on the Suncoast
      Quote Originally Posted by David Pozzi View Post
      I always wanted to get my cars closer to 52/48 with the fuel tank at 1/2 full (see I am an optimist). Of course I am lucky if I get 55/45 with a full tank.....now I am not feeling so optimistic.
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
    4. #24
      East, Tennessee
      Quote Originally Posted by Van B View Post
      This is why the first thing most guys do is move the battery to right rear trunk area.
      Yes but in my case it looks like it would have to go on the drivers side because my pass side rear is way heavy already and there isn't a thing in the trunk!!
      Scot W.
      1986 Buick T-Type
      RideTech, DSE, BAER Brakes, Forgeline Wheels, LED lighting, More!
      * Get your Top of the line GPS Theft recovery devices Here!
      www.GNSperformance.com
    5. #25
      East, Tennessee
      Steve's number of 52% is just the front weight in percent. At least between Steve and I, we talk about front percentage when comparing weight percentages car to car and leave off the rear percent. The general goal with our cars is to try and reach 50% front weight, but usually we only get to 53% to 51% at best. Stock for early Camaros is 56% to 58%.
      Your left front and right rear are heavier than they should be. IF the scales were perfectly level with each other, then you should try and lower any adjustment on those corners until they even up more. The left side usually is heavier than the right, - without driver. I disconnect front and rear anti roll bars when scaling, then connect them on the scales and shim them so they don't jack weight from one corner to the other. Raising a spring perch on the LF corner will increase weight on the LF and RR corners.
      Your left and right side weights add up to almost even, so by adjusting the heavy corners you should be able to balance them pretty close without driver.
      I like to do basic scaling without driver, just because the driver weight can vary depending on who it is. And I don't want to mess with placing 180 to 200 lbs of weight in the car every time I do a corner balance, and usually I don't have a spare person around the exact weight of the driver that can sit in the car. If the driver is around I'll sit him in the car for a weight when done.
      Here is an online calculator that should help, I haven't used it but it should work. http://www.opuscorvair.com/cornerweightcalculator.html
      When trying to even up cross weight you want to get close to 50%.
      David
      Thanks for the reply David,
      I used a set of those Taylor mechanical scales, zeroed them out and jacked the car up in the middle and then sat the car down on the scales front, then rear. I never thought about the scales being exactly level to each other while in the shop. I will check this as well next time!
      I also had a guy offer to loan me his digital pad scales so I will most likely take him up on it and do as you recomend by disconecting the sway bars and see if it measures any different than the first time. The passenger Rear is what is really confusing to me because there is No spare or anything in the trunk and 3/4 tank of gas.
      I will do that and report back.
      Scot W.
      1986 Buick T-Type
    6. #26
      Central CA USA
      You only need to disconnect one end link on each bar, then as they are connected check that you didn't jack any weight the wrong way. Washers can be installed to correct end link length up front. If you can't shim the end links on the rear, then shim the mounts.
    7. #27
      May 2002
      Northern California
      LOL, I just saw your sig David. LOL
      ahhh forgot what I was going to add. sorry.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    8. #28
      Aug 2009
      Country Flag: Chile
      hi guys,sorry to get involve in this topic but its a very interesting to me.
      I do race my 80 malibu as a road course,and am planning to weight it the next week,but something got me really confussed.
      For logic the front end of the car will be more heavy then the rear right?
      How do i increase the rear weight ? if my car have the stock suspension? i mean no coil over,i veheard something about the shims,but i dont know how they works,and how to fit them?.
      Anybody can help me? and teach me?
      thanks
    9. #29
      Aug 2008
      Pgh, PA
      Quote Originally Posted by xxxturbo6 View Post
      The digital scales are real nice. That's what I borrowed to weigh my ride. You first set the scales up and calibrate them and then lower the car onto them. They do all the math. FWIW I was extremely surprised that my car was so close to 50/50 (actually, 25/25/25/25) as I expected it to be much more biased to the front. It's heavier than I'd like (3700) but 50.6 front, 49.4 rear, just about exactly equal left to right. Weighed it twice before I was convinced.
    10. #30
      Oct 2009
      New Derry, PA
      Today I Scaled the car using TOLEDO mechanical scales from my local Round track shop. They said these are the most accurate so I went ahead and got some numbers. 3/4 Tank of Gas!
      I'm wanting to get the percentage between the front & rear, Can someone tell me the formula to achive this correctly?
      (With Driver/ Me)
      LF = 1085 lb
      RF = 986 lb
      .....................Total = 3,632 lb (Car with Driver "me")
      LR = 788 lb
      RR = 773 lb
      Scot W.
      IMO, looking at the car with driver is the most accurate measure, as that is how the car will be used. I agree the first step would be to disconnect the bars and re-check the weights. Check ride height (on a level surface) at the side frame corners and see if the car is sitting level. A few fractions of an inch would account for your weight readings. Also, were the tire pressures set correctly?
      Having said that, 15lb of split across the rear with a 1500+ lb. axle weight is nothing to spend any money trying to correct. Driver weight seems to be distributed logically. Unless you have coliovers or jack bolts in there, there's not a lot you can do to alter the cross weights, short of moving components around, as others have mentioned.
    11. #31
      Oct 2009
      New Derry, PA
      Quote Originally Posted by malibu43 View Post
      thanks
      The only way to alter the overall F/R weight distribution (at a fixed ride height) is to move components from the front of the car to the rear. Shimming springs will add or subtract weight from a given corner, but the total axle weight will not change.
      Be careful about moving things around to get more rear weight, though... The closer to the rear bumper you get with the battery or whatever, the bigger effect it will have on weight bias, but that weight will also become a pendulum during cornering, which can have a drastic effect on handling balance.
    12. #32
      East, Tennessee
      Quote Originally Posted by exwestracer View Post
      I agree, Next is to re-scale the car and do what Dave recomends by removing One link F&R and see if it's different from the first measure.
      Thanks to everyone for all the help and quideance on this subject, Please keep the tricks and tips coming, looks like it's helping others as well..
      Scot W.
      1986 Buick T-Type
