    Results 1 to 20 of 32
    Thread: Corner weights
      East, Tennessee
      Corner weights
      Today I Scaled the car using TOLEDO mechanical scales from my local Round track shop. They said these are the most accurate so I went ahead and got some numbers. 3/4 Tank of Gas!
      I'm wanting to get the percentage between the front & rear, Can someone tell me the formula to achive this correctly?
      (Just the car by it's self)
      LF = 997 lb
      RF = 956 lb
      ......................Total = 3,389 lbs
      LR = 695 lb
      RR = 741 lb
      (With Driver/ Me)
      LF = 1085 lb
      RF = 986 lb
      .....................Total = 3,632 lb (Car with Driver "me")
      LR = 788 lb
      RR = 773 lb
      Scot W.
      1986 Buick T-Type
      RideTech, DSE, BAER Brakes, Forgeline Wheels, LED lighting, More!
      * Get your Top of the line GPS Theft recovery devices Here!
      www.GNSperformance.com
      Aug 2006
      Belforest, AL
      1953 + 1436 = 3389
      1953 / 3389 = .57627 = 57.6% Front Bias
      1436 / 3389 = .42372 = 42.4% Rear Bias
      I seriously doubt that's what you're looking for though..
      Todd S.
      "I like to race school buses..."
      East, Tennessee
      Quote Originally Posted by LateNight72 View Post
      1953 + 1436 = 3389
      Todd,
      That's good to know too but i'm not sure that is what i'm looking for, hell it might be!! LOL. I think what i'm looking for is " The percentage difference Between the front and rear weights". Like Steve Rupp did with Bad Penny, he had came up with 52% difference but not sure how he came up with that number.
      Maybe Steve or Dave pozzi will chime in with how Steve got that number and their personal thoughts on my numbers..
      Scot W.
      1986 Buick T-Type
      Macon, Ga.
      He got the number the same way as above Scot. 52% is a good number. 57% is not, though most of our cars are similar. You want to be as close to 50/50 as possible. I think the charger is 56/44.
      Looking at the top set of number with car by itself, it is a bit strange that the LF and RR are heavy. battery must be LF and spare tire RR?
      Bill
      Trailers are for BOATS!
      Feb 2008
      Quote Originally Posted by Bill Howell View Post
      Yes, no, maybe?
      It's a little more contentious than that IMO. A lot of well setup front or front-mid rear wheel drive cars have greater than 50/50, you often see stuff like 45/55. More weight over the back - 1) Allows fuel loads to be accounted for and 2) Allows the rear wheels to provide more traction.
      Matt Barr.
      Macon, Ga.
      Quote Originally Posted by Bad Bird View Post
      Yes, no, maybe?
      While I agree with you, that is probably not going to happen with many of our cars here. I am not sure I know of any protouring cars, street driven, real cars that are 45/55. I of course could be wrong, wouldn't be the first time. That is why I used 50/50 as a reference for Scot.
      Bill
      Fontana, CA
      For a front engine rear drive car, 50/50 is about as close as you can get.
      Nick R.
      Greenwood, SC
      Yea, I would say Tony's corvair is probably somewhere in that ballpark.
      It's more than just 52/48 or 56/44. The distance between the center of these two "masses" is also important, if not more important.
      JC Scott
      Macon, Ga.
      Quote Originally Posted by cheapthrillz View Post
      LOL, you ever looked at a 72 charger? Then you KNOW how screwed I am here....haha I got about three feet in from of the front tires and the same out back.
      Bill
      East, Tennessee
      Thanks Bill, Now I have somewhere to start this process.. Thanks for jumping in with your thoughts!
      Scot W.
      1986 Buick T-Type
      East, Tennessee
      So would you like the measurment between those two masses?
      Here are a few more numbers on our GNS test car:
      Wheel base: 2746mm - 108.1in
      Track
      Front: 1486mm - 58.5in
      rear: 1466mm - 57.7in
      Length: 5095mm - 200.6in
      Width: 1819mm - 71.6in
      Height: 1387mm - 54.6in
      Length/wheel base: 1.86
      Drag Coefficient: 0.410
      GNS
      1986 Buick T-Type
      East, Tennessee
      I agree Bill! This has been really strange to me as well. Opposite! The battery is on the RT front and the spare is on the RR (Both passengeer side) "BUT" the spare was left out so the whole trunk was empty!!!
      Please keep up with the thoughts on these numbers as they are as much a wonder to me as well as everyone else. I just want some advice from the pro's on what they mean and what to do to change them for a better performance stand point!
      This is my first go around with these things and I want to do things right the first time. ANY input is good input!!!! LOL
      Scot W.
      GNS Performance
      1986 Buick T-Type
      Mar 2010
      AZ
      My guess for your side to side imbalance is your swaybars. If you can, disconnect the end-links on your swaybars and re-weigh it.
      Robert R.
      1988 S10 blazer 5.0L SBC 700R4 body off build.
      1991 S10 Blazer 4.3L too low daily.
      1975 Cutlass Salon currenlty 350/th350
      Stupidity should be painful.
      Greenwood, SC
      Don't get me started on boats again lol. At least your seats are comfortable!
      JC Scott
      East, Tennessee
      Still looking for an answer on how to get a % difference between the front and the rear.
      Example: (52% more in front vs the rear)
      Scot W.
      1986 Buick T-Type
      Greenwood, SC
      1953 + 1436 = 3389
      This is the only thing I can figure you're looking for....
      57.6% of the weight of your car sets on the front tires.
      JC Scott
      East, Tennessee
      Okay, That's all I wanted to know.. I wasn't sure if that was how the other guy's got their number or not, no one really mentioned it. So judging by this formula below (with driver) my number is now 57% ?
      Front: 2,071 / 3,632 = .5700 = 57%
      Rear : 1,561 / 3,632 = .4300 = 43%
      Okay, looks like we need to loose some weight up front and possibly transfer it to the lighter corner in the rear??? lol
      Scot W.
      1986 Buick T-Type
      Macon, Ga.
      Just streach the steering column, put some extentions on the pedals and drive sitting in the trunk, that should do it for you...haha
      Seriously, while 50/50 would be a dream, don't count on ever getting there in a street car, just get as much as you can off the frontend. If you get 53/47 that would be huge.
      Bill
      May 2002
      Southeastern WI
      Quote Originally Posted by xxxturbo6 View Post
      Scot W.
      This is why the first thing most guys do is move the battery to right rear trunk area.
      Jeff
      Central CA USA
      Todd,
      Scot W.
      Steve's number of 52% is just the front weight in percent. At least between Steve and I, we talk about front percentage when comparing weight percentages car to car and leave off the rear percent. The general goal with our cars is to try and reach 50% front weight, but usually we only get to 53% to 51% at best. Stock for early Camaros is 56% to 58%.
      Your left front and right rear are heavier than they should be. IF the scales were perfectly level with each other, then you should try and lower any adjustment on those corners until they even up more. The left side usually is heavier than the right, - without driver. I disconnect front and rear anti roll bars when scaling, then connect them on the scales and shim them so they don't jack weight from one corner to the other. Raising a spring perch on the LF corner will increase weight on the LF and RR corners.
      Your left and right side weights add up to almost even, so by adjusting the heavy corners you should be able to balance them pretty close without driver.
      I like to do basic scaling without driver, just because the driver weight can vary depending on who it is. And I don't want to mess with placing 180 to 200 lbs of weight in the car every time I do a corner balance, and usually I don't have a spare person around the exact weight of the driver that can sit in the car. If the driver is around I'll sit him in the car for a weight when done.
      Here is an online calculator that should help, I haven't used it but it should work. http://www.opuscorvair.com/cornerweightcalculator.html
      When trying to even up cross weight you want to get close to 50%.
      David
