    Results 1 to 16 of 16
    Thread: Ls starter
      St George Utah
      Ls starter
      OK am i the FIRST ONE.
      the starter i have is too Short to meet up with the flywheel.
      i have a LQ9 whth the thick crank flange and the original starter.
      i Have a Mcleod Aluminum flywheel that is listed to fit 97-06 LS ALL
      I need a starter!!! that a the nose cone that is 3/8" longer
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Jun 2010
      spokane
      What year lq9
      Sorry i am tired i checked part # for 01 ls1 and lq9 showing different part #s . Having trouble finding what the difference is though.
      Jun 2010
      spokane
      checked with parts dept
      I checked with our parts dept the starter for auto and manual trans 6. 0 is the same the auto flexplate had a spacer or was concave to make up difference in depth . The ls1 shows a different part # for manual trans . They dont have specs for # of teeth on flywheel or diameter .
      St George Utah
      thanks. i have been told by Mcleod that the 99-00 Truck 6.0L only starter might be correct any change of checking that?
      Blake Foster
      435-628-4300
      St. George Utah.
      Jun 2010
      spokane
      yea
      I checked the part # reman starter 6.0 same 99 ton 05 . The starter for 00 z28 shows different part number . Do you have the flexplate that came on the engine . How mant teeth and is it flat or concave .
      St George Utah
      I'm screwed!!!
      now i have to custom make a starter!!!
      YEAAA!!!
      Blake Foster
      435-628-4300
      St. George Utah.
      Jun 2010
      spokane
      this might work machine the adapter plate for proper depth
      Everything i found says because of the longer crank the ls1 flywheel does not work but this may be worth looking into
      Jun 2010
      spokane
      Its still cheaper than a gm starter
      The gm starHIGHEST TORQUE
      Most Efficient
      No Heat Soak Problems
      Clears All Headers
      Clears Oil Pans Where OE Starter Will Work
      Billet Aluminum Adapter Block
      4.4:1 Gear Reduction Ratio
      Cranking Power For up to 18:1 Compression
      Mounting Bolts Included
      Dyno Test Results Included
      Weight: 8.0 lbs.
      ter is 350$ that one is 240
      Crown Point, Indiana
      I am not trying to be a smart a$$ but do you think you have the flywheel on backwards? My buddy did this but it was just an older block not an LS.
      St George Utah
      Quote Originally Posted by GRNOVA View Post
      HaHaHaHa lol
      no i think i got that part right.
      so i ended up getting the Powermaster 9504? and then my Wizard took it home and remachined the entire thing and he just phoned to tell me it looks like it will work.
      so there you go.
      if anyone runs in to this issue again we now know how to fix it!!
      but it will cost you.
      Blake Foster
      435-628-4300
      St. George Utah.
      69LAnd
      ok i know that certain lq9 engines came with a long crankshaft so you may have the wrong flywheel
      on early lq9/4s
      Rick M.
      hMMMMMMsss....
      1969 Camaro real RS SS DSE LS3 6M TWiiN TURBO in the make!(taking forever!!)..any donations apreciated hehe
      69LAnd
      check and see if your engine had the crank flushed with the rear main or was it sticking out ?
      Rick M.
      hMMMMMMsss....
      Sounds like a 99 new body style 6.0 starter would have worked.
      Nathan Shaw
      71 Nova, 1000+whp 5.3, 8 second autoXer.
      Jun 2010
      spokane
      The 6.0 flywheel for 99 to 00 different
      The 6.0 flywheel for 99 to 00 different part # than 02 for manual trans they must have compensated for the longer crank flange in the flywheel . Thats why starter part # stays the same for 99 to 05 .
      Quote Originally Posted by killer69 View Post
      HaHaHaHa lol
      so there you go.
      What will you do when your starter goes out in the middle of nowhere?
      Nov 2000
      O-town
      I'll go with PUSH or AAA/Allstate motor club!
