    Page 2 of 2 FirstFirst 1 2
    Results 21 to 27 of 27
      Master and slave was bought together and stock style. You confirm my theory that I've probably got the wrong clutch in first place. Since the bearing runs in contact with the fingers all the time I can't see how the counterweight in the dual friction should work properly.
      No mine does not have the spot for an external slave.
      Been wondering about the construction of the slave. It contains a spring that push the bearing forward and my guess was when I installed it the bearing should be pushed in at least halfway to have enought travel to release the clutch.
      Is there any data to be found somewhere on this?
      Quote Originally Posted by Torbjorn View Post
      If your bellhousing doesn't have an external slave mount then it is not a LT1 style T56. Also, since you have a hydraulic bearing that bolts directly to the front plate of the transmission then I'd say you have an LS style T56.
      To me it sounds like you have a bearing to finger issue. The bearing that is in the picture is designed to be in contact with the clutch fingers at all times. That is how a stock LS t56/clutch works. This makes it very hard to know exactly how much clearance you really have between the bearing and the clutch fingers. Also keep in mind your driving style. If you have you foot even slightly on the clutch pedal it might be exerting pressure on the bearing. So as the weights pull the fingers back towards the transmission there is force on the bearing preventing the fingers from going back.
      Do you know what hydraulic bearing that is? It doesn't look like a regular LS style bearing. Also, do you know the clutch MC bore diameter and how much stroke you have at the MC? All that is critical for proper clutch release and function.
      Aug 2001
      Connecticut
      Just to help confuse you... I ran a mcleod self adjusting throwout bearing (on a richmond 6 speed, but the throwout looked similar to your picture) and it was on a centerforce with weights for a couple years and I didn't have any slipping problems... -Dan
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Yea Dan That really helped
      Finally fell down on the McLeod RTX twin disc unit. Now installed , but not tested yet.
      One in the middle is a Crower tripple disk for our Top Doorslammer drag racing car
      Trow out bearing seems to rlease as it should to
      Been driving with the McLeod for a while now and i'm wery satisfied with it. It holds the power an pedal feeling is smooth an no heavier than with the dualfriction
      ALso found that I'm missing an small bushing between the gear shifter and linkage inside the trans.This makes it hard to get into either revers or first gear
