Photo is of the left/driver's side wheel. The caliper and bracket are on the wrong side of the axle. Recently I installed the rear Baer kit on my MCSS 7.5" axle. Caliper was at 4 o'clock which places the parking brake mechanism at 6 o'clock. This assumes mounting for the 12-bolt is same as the 10-bolt.
Also in my instructions for G-body using the stock master with adjustable prop valve, are directions to remove the rear axle valve inside the prop valve.
