Results 1 to 20 of 42
Thread: LS weight savings
07-17-2010 #1
- Jul 2010
- 5
LS weight savings
I am just starting to plan a build and could use some advice. A friend sent me here and said you guys knew your stuff.
I want to build the most useful car possible. I have a Chevy 454 but was curious about reading about weight savings with the LS motor. What kind of real world advantage would the LS give me over my 454. My 454 has a lot of torque and HP, more so than a standard LS. Does the weight of the motor make that much difference or could you offset the negative handling effects by relocating the 454?
07-17-2010 #2
- Jul 2010
- 5
Also looking for the best possible 2nd gen camaro suspension. Wow there are a lot of options now. DSE, Speedtech, Schwartz and others I can't think right now.
How does one go about deciding which to pick?
07-17-2010 #3I've often wondered about the weight savings too. I'm no expert but I think the better handling will out weigh the power of the 454 and you can always build an LS to make as much power as you want.
07-17-2010 #4
