    Results 1 to 9 of 9
      Jan 2010
      Glendale, AZ
      Shifter relocation
      im building a 87 mustang and i am moved the seats, pedals and steering wheel back to get some weight back. the problem is i cant if i move the seat to where i want it i wont be able to reach the shifter i have been looking for ways to move it back and came up with a way i liked i want something like this.
      does anyone know where to get the handle and part that bolts to trans the rest i could fab thanks!
      Sunny Florida on the Suncoast
      I am thinking that this is going to test your fabrication skills. It really isn't that difficult to make if you have access to a mill. The shifter in the trans is just a regular Tremec/Borg Warner deal with the handle unbolted and the adapter for the extension rod bolted in the handles place. The rest is basicly what you see.
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
      Jan 2010
      Glendale, AZ
      yeah that what im thinking thanks!
      Boonville, Missouri
      The set-up that you show costs about $1500.00 total. Other things can be done to cut costs out of it. We had this same set-up in our shop in Missouri. The handle is fabricated from Delrin and the aluminum bar-stock can be re-fabricated using tubing. The rod is the key and needs to be beefy as flex is the enemy in this situation. I'll look for the prints and share them with you.
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Boonville, Missouri
      That part that attaches to the trans. could be made from channel or angle.
      Tony Edler
      Illumin8s
      May 2001
      Mesa, Az.
      This should be failry straight forward to fabricate... I mean... you have the blueprint right in front of you
      Phillip
      Sacramento, CA
      you could just buy the one from Mustangs Plus. I have two of them and just built my own bridge extension to suit my arm length.
      http://www.mustangsplus.com/tech/spe...ter/index.html
      Dave Smith
      29 Ford Roadster Pickup blown 327 and stupid
      67 Chevelle 396/5 speed PT
      65 El Camino L79
      Quote Originally Posted by Bigblue73 View Post
      $1500 for that?
      damn..
      wouldn't it just be easier to make/buy a shifter handle that lays back to where you want the knob? up until a couple of years ago, many NASCAR Cup cars had a shifter handle that layed way back like that. but i suppose the amount of travel wouldn't lend itself to fast and easy shifting under racing conditions..
      Portland Or.
      Quote Originally Posted by novaderrik View Post
      $1500 for that?
      damn..
      i see the mustangs plus one is $189
      68 Camaro under construction
      -Chris-
