      Jan 2010
      Lethbridge, Alberta
      1969 Camaro Clutch Return Spring Mounting
      Would anybody have a picture of where the clutch return spring attaches to on a small block in a 69 camaro? I'm not sure if the headers are in the way or I'm just blind. Thankyou.
      1995 Camaro Z28 - 440 SB2.2, T56, 9", PB is 9.70 @ 142mph, 2011 Hot Rod Drag Week, 2nd Place BB/NA.
      2009 TBSS - TVS2300, heads, cam, meth, 11.66 @ 119mph on street tires
      Feb 2007
      USA, TN
      If it is like the Nova, the headers are in the way. I had to make a bracket and bolt it to the oil pan.
      Ma
      Headers are in the way. Stock there is a little wire extension that goes on the motor mount. I wrapped a stainless hose clamp on the header and hooked the spring to that. When I changed headers I welded a washer that I cut in half to the header pipe. works like a charm.
      Scott
      69 RS/SS X22 in prossess of full resto
      2002 F350 4X4
      2000 Z28 T56 331 RWHP
      Central CA USA
      Look for a little hole in the rear edge of the engine mount frame bracket.
