    Results 21 to 23 of 23
      Oct 2009
      New Derry, PA
      FYI - Howe lower control arms
      Just want to share some info from a recent experience. One of my students is building a 2nd gen Camaro that incorporates IRS, a full rect. tube chassis, and aftermarket front suspension components. I have dealt with Howe racing products a lot over the years, and have some respect for their reputation. In this instance, I was disappointed.
      We ordered Howe's "OEM Replacement" tubular coilover lower control arms for the Camaro. http://www.howeracing.com/p-7573-tub...placement.aspx
      Howe advertises these as being available in 15.5" or 17" lengths. We measured the stock 79 Camaro arms the student had, and they are 15.5" from pivot line to center of ball joint...sooo, he ordered the 15.5" arms. When they arrived (late), we discovered that they were shorter than the stock arms by 1". The Howe arms don't measure 15.5" at any sort of reference point I can think of. We hadn't built the front crossmember yet, so that wasn't a huge deal, but it gets better...
      The 2 arms that arrived weren't even the same as each other. The dimensions were fairly close, but 1 arm has a swaybar mount, the other doesn't The arm with no swaybar mount has a brace for the coilover bracket, the other one doesn't. One arm has a full height ball joint sleeve, the other side is cut away. Now the best part...keep in mind these are "OEM Replacement" arms... Camaro ball joints do not fit in the ball joint sleeves! They drop right through. The student had to work with a parts guy at NAPA going through various ball joint types until they figured out the sleeve fit an Impala ball joint. Which uses a different taper than the Camaro spindle...
      I'm going to go out on a limb here and say that Howe might just have worked with 1 or 2 Chevy Camaros over the years... I can't understand why they would advertise these arms as OEM Replacements when there are obvious differences and changes that have been made.
      No, we didn't return them due to time constraints with the class. The car is going together fine, but the LCA issues cost valuable hours. There is nothing wrong with the quality of the components, and the price is very reasonable; just make sure you know exactly what you are getting when ordering from Howe.
