      Feb 2007
      Tinley Park, IL
      Fuel Line Fitting Assembly Lube, Hardware Store Equivalant?
      Is there something I can get at the hardware store that's the same stuff as this assembly lube?
      http://www.summitracing.com/parts/EA...4ERL/?rtype=10
      http://www.summitracing.com/parts/AER-FBM3553/?rtype=10
      I wish they made an installation tool, these things are a PITA to get seated all the way on the hose.
      Nick
      Nick ~
      1969 Cutlass
      Keller, Texas
      On regular AN line I use straight dishwashing liquid. Never tried it on a pushlock style fitting.
      Greg
      1970 challenger convert-in process
      1970 barracuda-driver
      Dublin, CA
      Not sure of the dynamics, but I use white lithium grease to put mine together. I have used it on both fuel and oil lines with no issue.
      Brent
      1971 Camaro, LT1, 4L60E
      Feb 2007
      Tinley Park, IL
      Tried some gear lube, still hard to slide on all the way, but doable.
      Thanks!
      Nick ~
      1969 Cutlass
      Miami, FL
      A dab of engine oil, but more importantly, place the fitting against a vertically mounted piece of wood (door frame of shop) line up hose, and push in one continuous motion. For the 90 deg fittings, I use a vise.
      Rob
      Jun 2005
      Lynnwood Wa.
      I use a quick spray of WD 40.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Nov 2007
      Lafayette, LA, USA
      They do make a tool and it is dang near impossible without it. It has handles like a pair of pliers and you set the fitting in and it pushes the hose on. I can't remember where I bought mine but it is plastic and every time I use it I wonder if it is going to break but it never does.
      Aeroquip also makes a proper assy lubricant that I use but before that I just grabbed a can of wd-40.
      http://www.racerpartswholesale.com/p...Plumbing_Tools
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting - Holy cow - what a ride!!!
      See my build
      Jason
      Nov 2007
      Lafayette, LA, USA
      Here is the tool.
      http://www.summitracing.com/parts/AER-FBM3632/
      You put the fitting on the left side and put the hose in the right side, squeeze the right side to hold the hose then push it together. An important thing to remember is once you start don't stop because it seems twice as hard to move it again.
      See my build
      Jason
