    Results 1 to 16 of 16
      Nov 2007
      High ridge ,mo
      distributorless ignition
      i have a BBC twin turbo EFI engine with 16 injectors.i am trying to figure out who has the best complete ignition and fuel management system on the market and is reliable.let me know what you guys are using. thanks greg
      Sep 2002
      San Jose, CA
      If you want distributorless, than Electromotive Tec 3 is the way to go
      Just call me Brett
      Miami, FL
      Use the the BigStuff3 or FAST XFI and set up the crank and cam sensors as LS1 based. Then you can use LS1 coils on a true coil per cylinder arrangement.
      Jan 2000
      Thousand Oaks California
      Quote Originally Posted by Lowend View Post
      That's what I'm running in Motiv8r.
      Larry Callahan
      Oct 2006
      Norway
      LINK ecm
      Oct 2006
      NJ
      I run a Holley Dominator EFI system on mine. Works perfect.
      Dennis
      Moore Racecraft
      Oct 2002
      Houston,TX
      I am using the Tec3 as well, There is no question that it is a great system and can do whatever you need.
      James J.
      Jun 2005
      Lynnwood Wa.
      MegaSquirt.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Jun 2005
      Lynnwood Wa.
      Two more
      Oliver Shultz
      More Info
      Quote Originally Posted by Ollie8974 View Post
      MegaSquirt.
      Could you tell me more about your setup? I am thinking about doing the same thing. What version of megasquirt are you running? Are going to run in wasted spark mode? or are you planning to using a cam position sensor. MAP sensor, temp sensor,spark tables......?
      Jun 2005
      Lynnwood Wa.
      Quote Originally Posted by chickn View Post
      Is the car in your avitar the car you will be installing the MegaSquirt?
      I am running the MegaSquirt-II PCB 3.0 version, with a relay board. This setup has provisions for all the required sensors. This will be installed in a 79 Trans Am, with a traditional 455 Pontiac engine.
      I have some 36-1 trigger wheels for sale. They are 7.10 inch in diameter and laser cut. I am using a HEI distributor to fabricate a cam sensor.
      This link is to the MegaSquirt site if you have not found it yet.
      http://www.bgsoflex.com/megasquirt.html
      The original plan was to run wasted spark using an EDIS module. The project is on hold awaiting the arrival of the next batch of MegaSquirt - III Daughter Boards.
      The MS-III will permit the use of sequential spark and fuel injection.
      The below link is to diyautotune page for the MS-III Daughter Board.
      http://www.diyautotune.com/catalog/m...45aa472e76c13a
      Oliver Shultz
      I plan on installing it my on 69 firebird. I'm in need of something new to play with. I thought it would I would get my feet wet with the ignition side of megasquirt then in the future do EFI. After reading the website, I plan on waiting for ms-III daughter board. Please post your progress.
      Holley HP or Dominator can run 16 injectors and has its own DIS system as well as standard features.
      I run the DIS on my car and just tuned a 1700HP nitrous drag radial car with the DIS the other week. Went 4.9's at 149 in the 1/8th.
      Jul 2008
      Strasbourg, France
      Country Flag: France
      I have the MS3 board (one of the first 50).
      I didn't stat the car yet, I am missing the tank and the MS3X which has not been released yet.
      If I manage to get everything done before getting the MS3X, I will start the car in batch mode. (for the moment ,I have a vortec distributor for ignition and cam sensor)
      With the MS3 and MS3X, you can use directly the LS2 coils for COP and distributorless ignition.
      Jun 2005
      Lynnwood Wa.
      Diyauto tune just announced the next batch of MS 3
      Oliver Shultz
      May 2010
      Orange, CA
      One of the guys at work swears by this http://www.motec.com/home
      and he's gone 6.08/241 with a 377" SBC and a pair of 94's
