    Results 1 to 20 of 22
      Mar 2003
      Kirkland, WA
      Vintage Air Frontrunner installed.
      I got my Vintage Air Frontrunner mocked up on my engine. It's a really nice system, but I have to figure out how to make the thermostat housing work. I attached a couple of pics of what it looks like, and what the issue with the thermostat is. I basically have 1.25 inch from the manifold to the bracket, and the centerline of the thermostat is 5/8 inch above the bracket. Any ideas? Anyone know how big the fitting that goes on a 16 AN outlet is?
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Mar 2002
      North California
      Looks good so far! i don't know the answer to the question,but i was curious about the size or what lines do you run for the power steering?
      Are the fittings AN? and where can you purchase the right lines or fittings?
      Anyway,keep up the great job...looks nice! That belt throwing will be a thing of the past!
      Mar 2002
      Redwood City, CA
      Dude, that looks awesome on your motor, but I don't think you'll get a housing to fit behind that without a lot of machine work. Had you waited, I think you'd be able to run this one. http://www.billetspecialties.com/ite...pid=649&rdir=1
      Allen Ortega
      Mar 2003
      Kirkland, WA
      I don't really like the Billet Specialties unit, too "hot rod" for me. I can draw one that will fit in CAD, should be pretty simple really. I just haven't found something ready made yet,although some pieces look close. Does anyone know if the LS1 uses the same thermostat housing mounting pattern? A standard water neck is about 1/4" too thick to fit.
      I still have to run all of the fittings and lines, I had an inkling about the thermostat issue, so I mocked it up to see how it all fit together.
      James
      -1996 Z28
      -2005 Silverado
      Webpage
      Nov 2002
      Georgetown,TX
      Looks good,James. I'm looking forward to installing my Frontrunner.
      Mar 2003
      Kirkland, WA
      Thanks Clint, it looks even better in person, I'm really happy with it. Once I figure out the thermostat thing, I'll be ready to bolt it all together permanently.
      James
      -1996 Z28
      -2005 Silverado
      Webpage
      Nov 2002
      Georgetown,TX
      I haven't received my Gen-II a/c unit and Frontrunner set-up from Vintage Air,yet. It should be arriving soon,though.
      I ordered the p/s pump and hose kit from DSE. Pricey little bugger.
      The Netherlands
      Country Flag: Netherlands
      I believe it can be done and look good...but do show some pics when and how you've solved it!
      Martin
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
      Mar 2003
      Kirkland, WA
      This is kind of what I'm thinking. It basically is two pieces of turned round stock, and a couple of tabs to bolt it on.
      James
      -1996 Z28
      -2005 Silverado
      Webpage
      Camarillo, Ca
      the ac compressor looks to be upside down according to the ones i've done. the fittings should be at the top to avoid oil loss. just obsreving...
      Camarillo, Ca
      but the cross ram is to cool..
      Mar 2003
      Kirkland, WA
      I was wondering about that.
      James
      -1996 Z28
      -2005 Silverado
      Webpage
      Pittsburgh, PA
      Fabrication....
      Hey James,
      Are you gonna run a thermostat??
      If not I was thinking you could run a thermostat block off plate that is available from circle track suppliers.
      Then you could drill & tap it (or weld on) an -AN to pipe fitting wherever you need it.
      Shane
      Dunwoody, GA
      what about using one of those o-ring housings that allows the neck to rotate? you would probrably have to put it on before the bracketry for the system and you would most likely have to pull the bracket forward if you want to get it off, but it may work for you. just a thought.
      also i dont know if it will be a problem for you, but we put one of those systems on a 65 vette with a ZZ4. the crank pulley sat so close to the front frame crossmember that you could not get the belt in there. we had to put longer bolts on the motor mounts and use a second plate in there to raise it up. they were energy suspension mounts which are identically sized to stock. getting the heater hoses onto the water pump is a pain too. great looking system though. really turns heads.
      Trey
      ~ Jon Hammond
      Maybe an offset housing made for blower apps will work. Try Weiand's website.
      http://www.holley.com/types.asp?type=143
      Mar 2003
      Kirkland, WA
      I looked at the offset water necks, but I'm not sure that's the look I want, plus they are way spendy. It's not the hose fitting that interferes with the bracket, it is the housing itself, the swiveling models stick up even more. I think I'm going to buy $20 in aluminum and build my own, since I have access to a TIG machine and a lathe.
      James
      -1996 Z28
      -2005 Silverado
      Webpage
