    Results 1 to 10 of 10
    Thread: LS 6.0/TKO ?'s
      Houston,TX
      LS 6.0/TKO ?'s
      Planning on running a TKO 600 behind an iron block 6.0 in my 71' Nova. Was curious of what you guys are running for a bellhousing, clutch, & flywheel w/ an LS/TKO? I would like to run a GM ls7 clutch, flywheel, and pilot bearing but haven't been able to get a clear answer on if this will work and what bellhousing I will need to run? I have a new CC5speed "621" aluminum bell I was planning to use on another motor, but am unsure if it will clear the ls7 clutch and work w/out probs w/ the 6.0? Will be running mechanical clutch linkage also..... Did a search and didn't turn up much info, someone enlighten me!
      71' Nova - LY6, T56
      Aug 2003
      I know the aftermarket blow proof bells will clear. the 621 is made for a big clutch, I would think it works. Best thing to do is order the clutch and flywheel package, set it on the floor and see if the bel housing clears it. if not, buy a blowproof.
      You will just have one bolt on the roof top you won't use.
      Houston,TX
      Quote Originally Posted by ProdigyCustoms View Post
      Thanks for the info Frank, honestly I was hoping not to have to run a blowproof bell, but will do so If I have too. Any drawbacks from not being able to utilize that top bolt? Is it just the "621" that doesn't have accomodations for it or the aftermarket stuff as well?
      71' Nova - LY6, T56
      Scottsdale, AZ
      I just bought a quicktime bell housing from summit for my ls7. If you want a factory LS7 set up I have one in good shape with 9000 miles on it.
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Houston,TX
      Quote Originally Posted by Cdog View Post
      I'm not sure the stock ls7 bellhousing will work w/ the tko? But will keep that in mind....
      71' Nova - LY6, T56
      Scottsdale, AZ
      Quote Originally Posted by NvrDun71 View Post
      I don't know either. I think it mates up to a torque tube. But I have the clutch and pressure plate with low miles too.
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Houston,TX
      Yea, the bell will not work, but will keep you in mind If I can confirm on the rest of the parts. Anybody else have any input on this?
      71' Nova - LY6, T56
      Click on my link for my GTO build. I used a Richmond trans, but the TKO will fit exactly the same way. I used a LS7 clutch. Link in sig.
      The 621 Bell works fine.
      Dec 2009
      I just got my LQ4/gforce 4 speed on the road, and used these parts, everything bolted on with no hassles.
      Mcleod Flywheel Steel, Special LS-X .200" Added to Face. 168T $150 new on ebay from Mcleod
      Mcleod 8650 bellhousing, can find for $250 if you look
      Centerforce clutch kit DF612909
      The extended pilot bearing, standard throwout bearing and lever
      Just another setup that worked.
