    Results 1 to 9 of 9
    Thread: Turn Signals
      Sep 2007
      Montgomery, Tx
      Turn Signals
      Left front turn signal not working.
      But with Hazards on all four signals work.
      Is there a way to check the signal switch?
      If switch is the problem what is involved in replacing it?
      Thanks,
      Gary Rys
      69 Camaro
      Sep 2007
      Montgomery, Tx
      No one???
      Gary Rys
      69 Camaro
      Fontana, CA
      Not sure about how to test a module, but replacing is simple. Unplug the old and plug in the new. It is underdash right behind the ash tray.
      Nick R.
      Rustburg, Virginia
      I would think that you could check the switch with an ohm meter....
      Sep 2007
      Montgomery, Tx
      HTML Code:
      ??? I thought it was behind the steering wheel?
      Gary Rys
      69 Camaro
      Rustburg, Virginia
      Quote Originally Posted by GaRys69 View Post
      HTML Code:
      I think he's talking about the turning signal blinker/flasher....the emergency blinker/flasher is probably plugged into the fuse panel, but the signal flasher is mounted elsewhere.
      Sep 2007
      Montgomery, Tx
      Thanks going out to the garage check now.
      Gary Rys
      69 Camaro
      Sep 2007
      Montgomery, Tx
      HTML Code:
      He's talking about the turning signal blinker/flasher
      Sorry was not thinking last night
      plus I am lost with this sparkie stuff.
      If the right side blinker woks fine
      could the blinker flasher still be suspect?
      All 4 hazards work, so dont think it is
      the bulbs or wiring.
      That is why I was wondering about the
      turn signal switch.
      Thanks again for all the help.
      Gary Rys
      69 Camaro
      Rustburg, Virginia
      I would try replacing the bulbs(sounds like a corny suggestion, but sometimes the filiment can be broken and do wired things)....check each socket really good for corrosion, add some diaelectric grease to each socket....check the grounds at each socket(use a ohm meter or a continuity testlight to verify the grounds), make sure you know whether or not that you do or do not have 12v at the light socket that isn't burning....rule all of those simple, pesky things first before we dive into the wiring harness or switches.
