Results 1 to 14 of 14
Thread: Modifying a sway bar?
05-03-2010 #1
Hello all,
Just curious. I would like to add some adjustability into my rear sway bar. What if I cut the standard bushing style ends off of the bar and then welded a tube over the end? I know this would change the properties of the material, particularly in the region of the weld, but I don't think it would really affect the material properties throughout the whole bar. Any thoughts on this?
Sean
05-03-2010 #2What kind of an application are you working with? There are already some known solutions out there
Just call me Brett
05-03-2010 #3I made these bar ends (BTW these started as 2" round stock turned milled and drilled)
Cut off stock smashed eyelets drilled the solid 7/8 bar and pressed then welded my ends on
I didnt like the stamped uchannel mount with the muffler clamp that was supplied so I made some solid Aluminum blocks and used 1/2 u bolts.
Then I didnt want heims top and bottom to eliminate any sound transfer to the chassis via solid connections so i made these links.
05-03-2010 #4
