Results 41 to 60 of 118
Thread: Trans Am SacrilEdge is free!
11-09-2010 #41
I have done a number of these 2nd gen TAs and my "go to" spot for the fuel pump is in the between the tank and the rear end. These cars came with a cross flow muffler there so if you use regular mufflers there is a bunch of room to mount the pump and filters. If you want to keep it behind the tank, as most suggest, you have to drop the tank and try and wedge it up between the tank and tailight housing. Not really much room up there but it can be done.
There is a new sump from Aeromotive that includes the pump inside the sump. That is pretty cool. The latest build I am doing will get a custom tank with internal pump I am thinking. We'll see how much room is left after the back half.
11-10-2010 #42Doug,
I saw that new aeromotive sump. I think it comes with two walbo 255 pumps, so if I decide to go f.i. then I'll definitely check it out, and I'll probably just let Rick's Stainless Tanks handle it
Greg
1976 Trans Am SacrilEdge
twin turbo 455
Ttops and 4spd
one of 110 made
https://www.pro-touring.com/showthre...ect&highlight=
https://www.pro-touring.com/showthre...ilEdge-is-free!
11-28-2010 #43New development. In case any of you were wondering if my modified shaker would seal well enough to build boost.....well, yes. It does. But the shaker itself might be the weak link. I only saw about 5psi at the engine, not sure about the shaker.
KER-PLOOEY!
I guess its time for Plan "B".Greg
twin turbo 455
Ttops and 4spd
one of 110 made
11-28-2010 #44Yep Carbon composite shaker ;-) ,,,,, and I just happen to know who can help you with that LOL...
Carbon Kustoms Limited
A.K.A. Albert from Toronto
11-29-2010 #45
