      Leaf Spring Install Question
      Feel kinda silly asking this but...
      Does it matter if the bolts are tightened with it on the ground? I was told the springs would settle, but after a few rears it's still jacked high in the back. I was wondering if perhaps they installed with the car on lift, and whether that would affect anything.
      Dec 2009
      El Dorado Hills
      What springs did you install? Can you post pics?
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
      They were built by a (at the time) local shop years ago. This was before I got on this board. Otherwise I would've been more selective.
      USA
      Well , you can always put the car on a drive-on lift and loosen the bolts , then bounce it to settle the car , and re-tighten.
      It probably won't make much difference in your ride height , but give it a try..
      Jeff Tate
      U.S.A.
      If I have to remove a leaf (it's a 5 leaf) which one should I take out?
