    Results 41 to 60 of 65
    Thread: 400 vs 377
    1. #41
      I have two different solid roller motors in the range you are looking at: an SBC with 3.75 stroke and 4.125 bore (400 with Bowtie block) and a cleveland "based" SVO motor with 3.45 stroke and a 4.165 bore (376 & dry sump too). They both have different personalities and valvetrain expense levels. If you are not spinning past 6500 rpm and you have decent components there really isn't a good reason to go smaller unless you want less torque and hp. You won't get as much power out of a 377 unless you spin it tighter (all other things being equal).
      Good luck
      70 Mach I, dry sump & lots of mods
      70 1/2 Z28 project car
    2. #42
      Oct 2005
      New Washington, IN
      another interesting arguement from someone with similer builds already.
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
    3. #43
      Oct 2005
      New Washington, IN
      Here is some interesting info. Of course not sure how accurate it is, but I ran both engines thru a sim.
      Using all the same parts, only different stroke.
      377 had a peak of 13hp more at the same RPM,
      40o had 1ft lb more torque at same rpm.
      Avg hp for 377 was 407
      avg hp for 400 was 390
      avg tq for 377 was 397
      avg tq for 400 was 387.
      This is not what anyone was predicting.
    4. #44
      A 400 makes less torque than a 377? Only if the heads are small and the cam is wrong.
    5. #45
      Mar 2002
      Redwood City, CA
      I ran my desktop dyno just now. Made one change, and that was the stroke. 3.750 to 3.480 to go from a 409 to a 377. HP increased by two at peak, but dropped 38 at peak and pretty evenly across the power band. It made the power band a little more broad by going to a 377, but it wasn't much.
      Allen Ortega
    6. #46
      Boston MA
      Quote Originally Posted by Johnny Blaze View Post
      Looking at 6.125 rods,mahle dished pistons that will put me at 11:1.
      Cam, I am looking at a solid roller either,http://www.lunatipower.com/Product.aspx?id=1993&gid=290 , or, http://www.lunatipower.com/Product.aspx?id=1976&gid=286
      Most likely will upgrade to 3.73 to make 6th a little more usable.
      Heads, I am unsure on, was thinking patriot performance 2121. 225cc intake runners, but am concerned that might be a little big.
      Headers are 1 3/4" primaries as well.
      Intake, will probably have to comaper, but either performer rpm air gap or victor jr.
      Thoughts?
      You're splitting hairs over rod length and specing a solid roller but then going to put a pair of chinese heads on it? I guess I don't get what this is all about.
      You've got a 3200# car with a six speed and a 6500rpm limit. You're going to have to work VERY hard to rationalize a 377.
      1967 #s RS
    7. #47
      Belle Plaine, MN
      I built identical 355 and 383 engines to see the difference a few cubes makes. The only difference was the stroke and piston. Both had CNC-finished AFR 210s, solid rollers, Air Gaps, and Demon carbs, 9.7:1 compression, Calico Coatings on the chambers, valves, and ports, and MSD ignitions.
      Here's the story with the results: http://www.compcams.com/Community/Ar...?ID=1945664039
      The 383 in the story is the one in my wagon now. I've been beating on it mercilessly for the last couple years now. It's awesome.
      Here's something I didn't expect- with the T56 and a 3.89 gear with 27-inch tall Nitto 555s, it pulls down just over 20 mpg on the freeway (1600-1700 rpm). Great little engine.
      More cubes are better. And you could use 210-215 cc heads on a 408 without any problems.
      Scott Parkhurst
    8. #48
      Oct 2005
      New Washington, IN
      Thanks Scott.
      wendell. I was just trying to weigh my options.
      As stated in original post, I have a block, but no rotating assmebly, so I figured I would see what the difference would be.
      I don't think I have been spliting hairs over rod length, I believe others in the discussion have placed more pressure on the rod length.
      I like solid rollers, what they big deal?
      I thought the patrioits were american made, not pro comps, but I guess i was wrong.
    9. #49
      Oct 2005
      New Washington, IN
      Fun cars,
      Both engines were speced out the same.
      200cc sportsman 2 heads, the above lunati voodoo cam, 11:1 compression, rpm air gap intake, 850 carb, open headers with 1 3/4" primaries.
    10. #50
      Feb 2009
      muggy midwest
      Yeah...this thread did seem to get carried away with a 377 vs. 383 attitude...lol. I prefer a long rod rotating assembly and with my combo it's actually more of a 350 cu. (using a 400 block) with a 6.2 rod and a 3.25" LG crank. Anyway, 62cc Fast Burn heads allow about 11.25:1 and runs on 91 octane....with an RPM ceiling of 8000 RPM. Desk top dynos are not my thing...your car's reaction will dictate just exactly how well it responds. I focus on rod angle more than most would to allow it to run way upstairs....more of a top speed, top end motor I guess you could say. But in the end, if 6500 RPM is your limit, a 383 build is hard to beat cost wise. If you planned to turbo charge it or super charge the engine, i would think differently altogether but as it stands...just do a 406.
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    11. #51
      Oct 2005
      New Washington, IN
      Yeah, looks like I will probably go with the 400, actually 409 with the .040" overbore.
      So those patriot performance heads are junk?
    12. #52
      Feb 2009
      muggy midwest
      I have no experience with them. I'd look at Dart or Brodix first.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    13. #53
      Jan 2007
      CT
      I'm running a 400 cid sbc. my configuration is as follows 409 cid sbc,
      afr 210 race ready heads, Victor Jr, 6" rod, Comp cams solid roller, KB pistons and 10.2:1 CR. HP flattens out @ 6700rpm's. But pulls good and hard right to it. I have a lot of fun with this combo. Good luck with what ever you build. For head IMHO I have used AFR's on 2 different 400's 195's and 210's with great success.
      good luck with your build.
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
    14. #54
      Oct 2005
      New Washington, IN
      Nick, that sounds right on with my idea,
      care to share cam specs?
    15. #55
      Jan 2007
      CT
      sure, its the xtreme energy grind i purchased 5+ years ago. If I remember correctly this is the grind http://www.compcams.com/Cam_Specs/Ca...?csid=307&sb=2. One think to mention buy the polymer distributor gear. I replace mine every couple years as safe insurance.
      ________________
      Nick S.
    16. #56
      Oct 2005
      New Washington, IN
      Cool. Looks pretty similer to the lunati.
      What trans /rear gears are you running?
    17. #57
      Cumberland, Maryland
      the other guy with the orange thirdgen says cubes.
    18. #58
      Oct 2005
      New Washington, IN
      Nice car!
    19. #59
      Jan 2007
      CT
      I have had 2 different trans behind this
      1st low buget trans was a super t10 w/ 3.42 1st gear and 2.73 rear gears it had okay first gear and highway but that was about it.
      I blew that up and and now running a LS1 style T56 w/4.10 rear gear. I don't have much miles on it yet but I like it so far. I am running a 30 LBS flywheel but have an 18 sitting in my garage ready to go on.
      ________________
      Nick S.
    20. #60
      Belle Plaine, MN
      Quote Originally Posted by nicks67camaro View Post
      LOL- That's the exact same cam I chose.
      I love it too - and also run the polymer dist gear.
      I run a T56 with 3.89:1s and a 27 inch tall tire. Love it!
      Nick- you must be pretty cool.
      Johnny Blaze- apparently that cam works pretty well in engines like this.
      Scott Parkhurst
