    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 65
    Thread: 400 vs 377
    1. #21
      Feb 2009
      muggy midwest
      First I would be curious on a production block how you would "bore out" a 350 block to 377 cu.
      Next, once you research the benefits of a longer rod and how it will allow you to run up to 11:1 on pump gas, then you will see the benefits...and this being a street engine to boot. If you want to know specifics on a big bore/long rod/short stroke combo, pm me for info-I can see this thread will easily get out of hand. I'll be dealing primarily with combustion chamber efficiency as it relates to volumetric efficiencies and timing. Once you see how you can run more compression, you'll give yourself more options.
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    2. #22
      Oct 2005
      New Washington, IN
      H2o pm sent
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
    3. #23
      Loganville, GA
      Quote Originally Posted by H2Ogbodies View Post
      Of course you can't bore a 350 out that much. I was referring to the lack of torque of a 377 comments when you don't hear the same thing about a 350. The only practical (or on paper) difference between the two is the larger bore. With a proper cam selection, the 377 could be a great street engine. Most just happen to be built to rev up pretty high, so people think they have no torque.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
    4. #24
      Oct 2005
      New Washington, IN
      I should say that our race car currently runs a big bore short stroke bbc as well as the motor the small block is replacing was a big bore short stroke combo, with much greater compression and cam.
      I think I have a good idea of a build, but my old computer died and desktop dyno will not let me install on another computer, what a scam.
      Time for a new sim program.
      Lunati has some new cam profiles that are big but suppose to be very streetable as well that look good for this build.
    5. #25
      Oct 2005
      New Washington, IN
      Anyone care to do some desck top dyno comparissons? Let me know and I will post some specs.
    6. #26
      Sunny Florida on the Suncoast
      The 377 can have good torque, like stated it is just a 350 with an overbore you can't do in a 350 block. The 4.165 bore will unshroud the valves nicely compared to the 350's 4.005 (or 4.045 assuming .040 over) bore. Again I own a 406 in a 71 Monte and love the torque but it is a 4000 lbs car with me in it so torque is my friend and the 406 has it, great big huge tire frying gobs of it. My 406 has GM production 5.7 rods to take care of some of the geometry limitations spoke of earlier. In a 3200 lbs car I would not worry about not getting enough torque out of a 377, run a minimum 6.0 rod with a good hyd roller or a mild sold roller it will be more than enough to light the tires. If you do the 377 I would change your gear selection to 3.55 or 3.73, with a 6th gear you can run those and not rev the thing cruising down the highway. If you go 406 then put the longest rod your budget will allow and go with the 3.23 or 3.42 gears, you can not go wrong with the 400's torque.
      Bottom line it build what you want, neither combination is a bad one.
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
    7. #27
      Oct 2005
      New Washington, IN
      Looking at 6.125 rods,mahle dished pistons that will put me at 11:1.
      Cam, I am looking at a solid roller either,http://www.lunatipower.com/Product.aspx?id=1993&gid=290 , or, http://www.lunatipower.com/Product.aspx?id=1976&gid=286
      Most likely will upgrade to 3.73 to make 6th a little more usable.
      Heads, I am unsure on, was thinking patriot performance 2121. 225cc intake runners, but am concerned that might be a little big.
      Headers are 1 3/4" primaries as well.
      Intake, will probably have to comaper, but either performer rpm air gap or victor jr.
      Thoughts?
    8. #28
      Feb 2009
      muggy midwest
      Hey Johnny-pm'd you back-you might be able to run with that combo...with 11:1. I would shoot for a 6.200 rod instead. Piston choice will be slim...but check out my pm first. JE has 'em.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    9. #29
      Oct 2005
      New Washington, IN
      Pistons, Mahle, SBC125165F05
      flat top for 4/165 bore 3.48 stroke 6.125 rod
      1.125 piston height
      452 grams
      11:1 with 64 cc heads.
      what about heads? is 225 too big?
    10. #30
      Feb 2009
      muggy midwest
      After thinking about it...I would stay with a 210cc head....moreover because I think you'll have better low/midrange response. Too much airflow (ie volume vs. speed) can kill your throttle response. Keep the vacuum signal strong and run with a slightly smaller head than you would expect to run. Strokers have a lot of piston travel so they benefit from larger heads but since your 3.48 crank won't travel as much, keep the cc's around 210 would be my choice. If you were shooting for an 8000 RPM engine I might think otherwise but for what you are shooting for, I'd say smaller is better. As for rotating weight, compare a 3.75 crank to a 3.48...that extra weight transfers to inertial weight once it's spinnign and that creates extra stress throughout the entire valvetrain...what I (and Johnny from the sounds of it...) shoot for is a rock solid rotating assembly, giving up a little bottom end true..but for a more balanced, higher/quicker revving with a flatter, more broad torque curve that extends well past the limits of a 383 or 406.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    11. #31
      Chicago suburbs
      Go 400- If it were 383 (4.0 bore) vs 377 (4.125 bore), then the 377 would be the better option. 3.75 is not that big a stroke, ZO6's have 4.0, and they don't seem to have trouble revving. I had a simular dilemma as you my last build, and went for the 400 standard weight stuff and I have no complaints about throttle response. If you want to feel a real difference, try a 3.0 stroke and build for upper rpm- I bet it would rev just as easy, probably easier then a 302. You might get sick of it on the street, though- smaller cubes tend to be peakier to reach "high" hp. Check out Nelson racing's site- they have video of a 302 thats pretty impressive. BTW- all things being equal, the bigger the stroke, the easier it will fail as RPM gets high
    12. #32
      Oct 2007
      For a 6500 rpm street car I would rather stroke the 400 but never destroke. A rotating assemblies for a 6" 406 is not too pricey.
    13. #33
      Feb 2009
      muggy midwest
      The architecture of an LS engine is vastly different than that of a standard SBC. Block stress with larger strokes is what eventually kills stroker motors....the LS blocks use 6 bolt mains and the location of the crank sitting higher in the main area adds to the strength of the rotating assembly-instead of the crank spinning halfway out of the block, more of it is contained inside the block which equates to the block itself acting as a main cap of sorts. Now, a lot of this stress concern goes away if you are using a Motown block vs a standard production block...but that's another story.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    14. #34
      Oct 2007
      I agree with you 100% I run a motown block. But the production blocks will take some abuse my friend races circle track with a stock block 421 on alcohol 7500 rpms never hurt a block. He simple abuses it!
    15. #35
      Oct 2005
      New Washington, IN
      I understand everyones desire for a torque monster on the street.
      I certianly see the need for it in a typical street car which truely weighs close to 4000lbs.
      However, I feel that my application is a bit different than a typical street car.
      My car has been gutted, abd with driver and big block was just over 3000lbs.
      With small block and 6 speed, I figure it will be a little lighter.
      Also with the six speed, the needs would be a little different that a th350.
      This car is not and will not be a daily driver, so it does not need to be super mild either.
      As most know traction is often the limiting factor of street performance.
      I am going with nitto 555 extremes on it this go around, 275/40/18 to be exact.
      I would rather give up a bit of torque than just blow the tires off.
      I am still in the air on which to go with. I actually have a set of pistons for the block for a 3.75 stroke and a 6" rod, but I would have to get the dome milled off to use get pump gas friendly compression.
      Please continue disscussion.
    16. #36
      Chicago suburbs
      Are you planning lightweight flywheel? Your build will be similar to a 383 in torque and hp ( longer stroke does not mean more torque because of "leverage"). Don't go overboard with the heads, though. Look into AFR 195cc eliminators. It's better to have "too torquey" of a motor than not enough, especially with a stick- thats why I mentioned the flywheel- you might be better off with a regular steel one. I have close to 400 ft lbs at the wheels in a 3160# car, and I wouldn't say I'd give up any torque.
    17. #37
      Oct 2005
      New Washington, IN
      Good to here some input from someone with a similer set up already.
      I had considered a lightweight flywheel but have never heard much good about them in a street car.
    18. #38
      Chicago suburbs
      I wanted a light flywheel & clutch, but I was talked into the steel stuff. It's heavy- billet flywheel = 30#, pressure plate probably another 20 or so, but on the upside, its VERY hard to stall. It really does not feel heavy when going through the gears, I never really think about it. I think you need a really strong power to weight to use the lightweight stuff, or a tall rear gear (4+). BTW- it probably has some to do with my novice driving style, but I noticed the car seems slower up to about 20-30 mph compared to my TH350 after my TKO swap. I may need to switch to a taller gear too. Even so, I'll never go back to an auto.
    19. #39
      Feb 2009
      muggy midwest
      Leverage directly applies to the stroke of an engine when it comes to torque-an engine makes power when the piston is slammed down the bore after combustion-now, what would make more torque....a piston connected to a 3.25" stroke or one with a 3.75"-it's basic mechanics here....more stroke equals more torque-to a point. The trade-off is where it becomes too ragged....and then cylinder wall loading becomes a factor.
      It all depends on how you plan to drive your car too-assuming you get good traction, lets forget about which engine type to build and imagine how your car will respond with regards to RPM changes if you are on a roadcourse with say, 3.73 gears and your 26.5" rear tire height. A 406 or 383 will want you to keep your powerband in the 2000-5500 range for the most part-your torque curve is the strongest along that RPM range. A long rod 377 will want you to stay in the 3000-7000 RPM range. In either case, when you are upshifting or downshifting coming in or out or corners, you would ideally want to keep the RPM drops between gears as close as possible-for this reason, I pm's you about using a TKO 5 speed instead of the T56. The gear ratios are much closer and it will make it easier to stay in your powerband. And for the most part, 6th gear is almost useless unless you are running 90 mph on the freeway with it.
      Now, if you have a wide ratio (relatively speaking) manual trans with a 406, knowing your RPM range is not as high as a 377, if you have several quick turns or corners that demand downshifts followed by abrupt upshifts, it's going to be very fast shifting to keep that 406 in it's powerband smoothly-a 377 will have a much broader operating range so that can allow you to "run the gear out" coming into a corner and then staying in it coming out...leaving you more time to focus on driving rather than shifting. Imo, this keeps the theme of having a light, nimble car that has an RPM range that'll let the motor sing a bit. So, if you can stay in one gear coming into and out of a corner, you can get a better idea of the cars handling characteristics because you don't have to factor in the jerkiness of downshift/upshift every time. In other words, an engine with a broad RPM range will allow you the ability to NOT shift whenever you want to...and you won't have to worry about the motor not holding together. It would be nice to see two identical cars run with the only exception being the engines...377 vs. 406.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    20. #40
      Chicago suburbs
      If cubes are EQUAL, short stroke/ large bore will not really have less torque than long stroke/ small bore. Thats what I was trying to get across when I was comparing the 377 to 383. I would much rather have a destroked 400 (377) than a stroked 350 (383). I don't know of a single advantage of the 383, except maybe popularity & availability. Maybe there's something I'm missing. Not only does the 377 have a bore advantage, but it's smaller stroke will survive more abuse than the 383, given equal strength parts. The 377 will not give up torque from its smaller stroke compared with the 383.
      BTW- I don't mean to turn this into 377 vs 383- I just want to clear up what I said earlier. As for the 406, If you buy a good bottom end, you will likely have valvetrain problems before the motor itself "comes apart". Most SBC's are valvetrain limited, and that goes for the 377 also.
