    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 42
    Thread: Relay box
      Hackettstown, NJ
      Relay box
      Tried finding an OE box that I could use w/ close success, but not what I was looking for. I decided to make my own. I plan to use 1/8" plastic/ thermo plastic and mold/ bend it to the configuration I desire. a basic rectangle w/ removable lid.
      Before I do such, is there a place that has fuse/ relay housing pre made? I looked at an index card holder and while the size was close, it was rather flimsy.
      I have 6 relays and the same amount of fuses. I would like room for 2 more of each.
      Feb 2009
      muggy midwest
      Take a look under the hoods of the LT1 4th gens...here's what I used for a 66 Chevelle drag car project-it houses plenty of room for relays, fuses, spares, IGN and HOT terminals, etc. Very compact and clean. I always source late model cars of every make for compact fuse panels-they aren't hard to find in a boneyard.
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Hackettstown, NJ
      thats looks exactly what I need. what years was that from? the lt1 4th gen was from 93-97. probably all the same.
      Feb 2009
      muggy midwest
      Yep...all years from 93-97 are the same. There are literally a ton of choices, this is just one of them. I have a lot of fuse panels from all sorts of vehicles...I espescially like the mini style fuse/relay panels...they are slick as well. I used this panel to power the fuel/nitrous solenoids, line loc, trans brake, aux. relay for fan over-ride, prim. and sec. fuel pumps, master arming, etc. Very handy.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      May 2007
      Las Vegas
      http://www.rallylights.com/detail.aspx?ID=772
      HL62943 Mini Relay Box, 4 Gang, Splashproof
      Hella
      Can be dovetailed with HL62942 16 gang fuse box
      Relays with brackets or fuses will not fit
      Relays Not Included
      $39.92
      Rich
      1969 Camaro (in hibernation)
      Melbourne, FL
      Quote Originally Posted by H2Ogbodies View Post
      I recently pick up one of these off a 93 Camaro at a local yard. I also grabbed the mount off the inner fender. $15 out the door!!!! Do you have a schematic for this box or know of one online somewhere? Too be honest I haven't had time to look yet. But if you can help out I'd appreciate it.
      Feb 2007
      USA, TN
      The Delphi panels are very cool. It is all I use for wiring. Best of all, they have OEM reliability. Once you crip one of the connectors, you'll never go back to Amp or anthing else. You should be able to find all the terminals and part numbers to wire it up in the Delphi catalog. Most of them use ISO 280 relays which are easy to find too.
      http://delphi.com/pdf/contact/brochu...balCatalog.pdf
      www.mouser.com sells most of the parts.
      Hackettstown, NJ
      pickup a fuse box from a lt1 4th gen. thanks for the lead, just about exactly what I needed. I need to find a cover. The junk was hit in the front and might have had the cover inside which was full of stuff or on the ground covered in snow.
      again, thanks for the lead.
      what are the terminal #'s? typical 56 series terminals are a tad thinner. look like 630 metric pack and AF for the fuses??
      Feb 2007
      USA, TN
      Quote Originally Posted by Takid455 View Post
      Termals will either be 280 or 630 if you got if from a GM car. Do you have a pic? If it has maxi-fuses, it will use 800. The most common are 280 for relays and fuses. They are easy to measure. 2.8mm is 280 and 1/4 inch is 630. Check the link to the catalog I posted above. If it has 280 buss bars, you will need to know if they 15 mm or 16.2 mm. On the 280 terminals, you will also need to know if they are tanged or tangless.
      Hackettstown, NJ
      the relay ones are 1/4" and spec out to be 630 w/ tangs according to measurements on the drawings like these: delphi # -12052227, 12015865, 12015864. (PG 7.5). I found terminals for 18-16, 16-14 and 12 awg at mouser.
      having trouble locating the fuse holders. mouser does not list the numbers in the delphi catalog 12131446 and 12131456. (PG 7.7) they are stated to be AF female terminals unsealed. any help to located some is appreciated. being this is soured from a Firebird, I'm assuming everything to be delphi, no? the picture provided in the delphi catalog and what I have appear to be similar.
      Feb 2009
      muggy midwest
      You know, a lot of times when I'm bored I just stroll through my local yards and check newer stuff out-I usually find a nice way the factory is integrating things like junctions, relay/fuse panels, etc. and whenever I see something I like, I incorporate the idea on every future project-whether it's for me or a customer. That Chevelle had a ton of stuff wiring wise-I basically built a harness on my wiring table and used prolly 25 different spools or wire just to put it all together. Then I tie in all the required circuits, test the harness outside of the car, then in it goes-then I cut/relabel as I go. I gave the customer a QuarkXPress document page layout showing the whole system. I have fun with wiring so for me it's no biggie but you gotta have a well thought out plan if you do your own wiring. This car has all the normal aftermarket doo-dads but a lot of stuff had aux. controls, over-rides AND had to have a total kill switch from either inside or outside of the vehicle AND I designed an anti-theft circuit for it too. My advice is to lay your plans all out on paper and make SURE they make sense on paper prior to pulling any wire. For example, with this guy-he wanted use his shifter button to both hit the nitrous off the line AND release the transbrake-I said I could do that but it may not be the best scenario...so after I went through the motions in air (literally!) and imagined what it would be like to leave the line hard with about 1000 HP at the tires with ONLY ONE HAND on the wheel while he released the 'brake, I strongly (but nicely) suggested we should think about safety and control and have the trans brake activate via the floor mounted dimmer switch...this way, you have both hands on the wheel and use the button on the shifter for the solenoids. So on paper the wiring all had to make sense. Once it all comes together, it's always great seeing it all work as intended with safety precautions planned in as well.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Feb 2007
      USA, TN
      I believe the first part number should be 12131446. I searched my usually sources for them and nobody seams to stock them. There are a couple of options
      1. Call Mouser and ask for a quote. They can get anything in the Delphi catalogs. The only down side is you have to purchase the quantity Delphi ships in. Sometimes it is 25 and sometimes it is 10,000. The quote is free, so I would ask.
      2. Since you know what car it came out of, go to the Chevy dealer and see if you can order them
      3. Here is the link to the technical drawing for the predessor part number. http://connectors2.delphi.com/dcsgdm...7.m001.tif.pdf. It looks like the same terminal sold in the Delphi's 4 terminal ATO fuse blocks kits. Painless sells them for a painful price. However, many autoparts stores sell them for about $5.
      Mar 2004
      Mid-Michigan
      I used a "Project Box" from Radio Shack to hide the relays for my trucks head and driving lights. I painted the box body color and it disappears on the fender.
      These are less than 10 bucks and R.S. has a number of various sizes.
      Mark S.
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Aug 2008
      Salt Lake City, UT
      I used a stainless steel access panel from a plumbing supply company, which I mounted in my fender apron. Then, I fabricated a metal box that attaches to the panel.
      67 fastback
      351w
      Baer brakes
      G-Force T5 trans
      9" rear w/3:50 gears & 31 spline axles
      Link
      Recently moved Salt Lake City from the SF Bay area.
      Looking forward to driving on the Miller Motorsports track this summer!
      Feb 2007
      USA, TN
      You could also use a NEMA 4X box. They can be submerged and sprayed directly with a hose. Some have cool clear covers. I used one for my fan controller
      CT
      Quote Originally Posted by garner67 View Post
      Very nice!
      Hackettstown, NJ
      called mouser and my local GM dealer w/o luck on the fuse terminals. any help in located some would be appreciated.
      Feb 2007
      USA, TN
      The best thing to do is find a box you can get the terminals for.
      Here is my setup. It is all new parts that are available at Mouser. There was only one part I couldn't get which hold two additional maxi-fuses. There are 10 relays and 26 fuses.
      Hackettstown, NJ
      what terminals do you have for the regular atc fuses? looking at the minis, they look like what I have/ need. looks like they are mp 280 series? wonder if I can 'make' them fit in my box?
      Hackettstown, NJ
      here are the terminals I have currently from the OE fuse box.
