    Results 1 to 12 of 12
    Thread: C5 converges
      Feb 2010
      C5 converges
      67ls,I have a 67 camaro with drum spindles on the front, would like to put on C5 corvette brakes calabers with C4 13" rotors. Is speedtech the only people who sells this braket.
      Mountain Springs, Texas
      I think Tobin at Kore3 also sells those brackets.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2010
      Tobin at kore3 only selles brakets for C5 rotors not the C4 thanks any way
      Jan 2010
      Elk River, MN
      I'd still give him a call, chances are even if he doesn't have the bracket you need, he can point you in the right direction.
      Oregon
      Touring Classics was the only other company that comes to mind offering a C5/C4 hybrid type of kit, and they're no longer in the biz as far as I know.
      Tobin
      KORE3
      It's what I does.
      Marshall , MO
      keep your eyes open here in the for sale section that is where I picked up mine for half price.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Feb 2010
      Chico, Ca
      Just out of curiosity, why don't you want to run C5 rotors?
      PM Dan ( 68sixspeed ) he can make or may have a set ready to ship.
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      Southern Indiana
      Actually Kore 3 has several hybrid setups too. But if I remember correctly the C4 uses a smaller rotor and C5 uses the 13 in rotor. As for a drum brake 1st gen you turn your drum hub down to 5.94" then slide on C5 rotor and Kore 3 brackets and C5 calipers, this way you need 17" wheels, if you use the Kore 3 hybrid it uses the smaller C4 12 in rotor and C5 calipers I believe is the proper way to explain it.
      Marshall , MO
      The HD c4 rotors are 13" they are not as thick as the C5 rotor and the off set is different allowing for more wheels to fit. I don't think Kore3 sells a C4 rotor C5 caliper kit because of the smaller thickness of the C4 rotor. Tobin explained it in a post once but I don't remember exactly what the issue is.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Apr 2004
      Cedar Rapids, IA
      When did that happen? Crap, thats way I wanted to go.
      Feb 2010
      Quote Originally Posted by nor_cal_67rs View Post
      because I have 17" torque thruster II wheels and the C5 rotors put my calapers to close to the wheel with the C4 rotos it backes them off the back of my wheel for cleance
