    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 66
    1. #21
      Lake Oswego, OR
      Yes the seats are out of a 2003 BMW M3.
      Lee
      1966 Cutlass
      The difference between truth & fiction: fiction has to make sense.
      Build Thread:
      https://www.pro-touring.com/forum/sh...ad.php?t=64470
    2. #22
      Lake Oswego, OR
      Just got in a set of ATS AFX spindles & steering arms, SPC Pro-lite UCA's, and SPC LCA's. Thanks to Mike (69496) for a smokin' deal on these. I guess suspension retrofit just moved to the front of the line!
      Lee
      1966 Cutlass
      Build Thread:
    3. #23
      Thomasville, NC
      Very nice.....my '66 will be jealous - LOL.
      1966 Pontiac Catalina Ventura
      389/TH400, Wide-Track Darksider
      Bars, springs, disc brakes, etc.
      1962 Falcon 2-dr
      "just getting started"
    4. #24
      Aug 2008
      Pgh, PA
      You're gonna love that stuff. I'm running all the same stuff except for the AFX spindles.
      A word of advice: Before you do ANYTHING else with that stuff.
      Pay close attention to how they are assembled, then get a good set of snap ring pliers. Remove both snap rings on both sides of the crossbars of the UCAs. Clean the crossbars well, then tape off the load bearing surfaces and the grease fittings. Then prime them with some etching primer, followed by painting them with a top coat. Re-assemble them. Make sure you lube the load bearing surface with some lube and make sure that you have each of the "flat" sides of the snap rings facing correctly. In other words, the inside one should face the center of the bar and the outside one should face the end of the bar.
      Those crossbars look great now. However, they won't stay that way. You can either try to constantly stay on top of them wiping them down with WD40 or something (though you'll never keep the cracks and seams lubed) or they'll get tons of light surface rust. It will not affect their performance, but it'll look terrible. Painting them up front is extremely easy and worth the time.
    5. #25
      Lake Oswego, OR
      wmhjr, will do. This is actually the first time I've messed with suspension so I'm in the process of figuring out how to disassemble/reassemble the whole shootin' match. Any advice is appreciated.
      Lee
      1966 Cutlass
      Build Thread:
    6. #26
      Aug 2008
      Pgh, PA
      No problem. It's easy stuff. First, check the instructions that came with the UCAs. You'll see that the part where the upper ball joint goes (the ball joint plate) there is a welded joint that an arm attaches to on one side, and a pivot bolt on the other side. The welded joint always goes toward the front of the car. They sometimes come assembled incorrectly, so you may have to reconfigure them.
      Beyond that, removing the crossbars is just a matter of having good, correctly sized snap ring pliers and expanding both sets of snap rings to remove them and then sliding the pivots off.
      It's easy - you'll see. Have fun. This is great stuff.
    7. #27
      Lake Oswego, OR
      Well I removed the entire front suspension and the steering box, intermediate shaft & steering column:
      Wheels are off--getting ready to order the Forgelines:
      I primed and painted the SPC UCA crossbars based on wmhjr's recommendation:
      I got some black SPC UCA sleeves from Marcus and reassembled the UCAs. I think they turned out pretty good.
      Lee
      1966 Cutlass
      Build Thread:
    8. #28
      Mar 2010
      Rochester NY
      Nice project!
      Don
      Grace - 67 Camaro daily driver with upgrades along the way.
      https://www.pro-touring.com/showthre...-Camaro-Driver
    9. #29
      Houston, TX
      Nice progress. Where are you located in Portland?
      Tu Ho
      Firebird V2-LS swap
    10. #30
      Lake Oswego, OR
      Quote Originally Posted by rickpaw View Post
      Near Bridgeport Mall.
      Lee
      1966 Cutlass
      Build Thread:
    11. #31
      Dallas TX
      Looking good man!!
    12. #32
      Lake Oswego, OR
      Thank you for the kind words Gents. Richard, I just hope mine turns out half as nice as yours.
      Lee
      1966 Cutlass
      Build Thread:
    13. #33
      Aug 2008
      Pgh, PA
      Nice job, Lee! Glad to see you continuing to make progress. Keep the pics coming!
    14. #34
      Lake Oswego, OR
      After SicMonte's post on his SPC UCA sleeves seizing up, I took the opportunity to anti-seize the living daylights out of my sleeves
      and then attached my SPC Upper & Lower Control Arms
      Lee
      1966 Cutlass
      Build Thread:
    15. #35
      Lake Oswego, OR
      Finally got the helical spacers in from SPC!
      TADAAAAA: assembled the UCA, LCA, SPC springs, VariShock QS2 shocks, and ATS AFX Spindles.
      Lee
      1966 Cutlass
      Build Thread:
    16. #36
      Nice progress. Sweet looking car too.
    17. #37
      Lake Oswego, OR
      Thanks Wayne.
      Lee
      1966 Cutlass
      Build Thread:
    18. #38
      May 2010
      Very nice Lee. I will definitely be comparing notes with you along the way!
    19. #39
      Lake Oswego, OR
      Thanks elements. I'm learning as I go!
      Lee
      1966 Cutlass
      Build Thread:
    20. #40
      May 2010
      Just posted a few engine and other specs on my thread. Check it out.
