    Results 1 to 9 of 9
    Thread: Spoiler options
      Nov 2009
      the dirty mitten
      Spoiler options
      I would like to avoid the lift that my car will produce at high speeds so I would really like some sort of spoiler on the deck lid. Something form fitting and tasteful or course but still very important and functional. I would like something bolt on and hopefully not standing more than 6 or so inches off the lid. I would also like it to follow the contour of the rear end instead of something just straight across. Is there anything available that I could modify to fit? Or should I get out the foam and shape my own to be made from fiberglass? This will be for a 1968 Charger. There is a small spoiler on the tail, but it is not enough. I have seen some cars with modified taller spoilers (Pure Vision did one that is not bad) but most are not to my liking.
      Steve
      Jul 2009
      Grand Rapids, MI
      I busted out some cardboard recently to start mocking one up. I hadn't thought about foam and glass but I'll be watching this to see what you do.
      Will Ellis
      Build Thread
      Nov 2009
      the dirty mitten
      What was your plan to build it using cardboard?
      I read you can use green floral foam then make the fiberglass piece around that. I was thinking about using a thin piece of foam with a 1/8 aluminum rod pushed thru it for stiffness. I can then lay the glass over if on both sides then glue the, together and put a few pieces of aluminum in it for added stiffness but hopefully not too much weight. I would then make the mount and strut to make it have adjustable pitch. I think the ends would be a piece of aluminum sheet maybe covered in glass too.
      Steve
      Nov 2007
      crossville,tn
      Balance front to rear is a trick, the more downforce the better the driver feels. American car makers follow a general aero profile, nose, windshield, rear window,ect. These profiles warrant about 6" at 35* to produce consistent downforce at 50+mph without massaging the body.
      san diego
      If you use the floral foam cover it with aluminum foil. The resin with solubilize the foam.
      Or find some surfboard foam from a core maker. The usually will give you some leftovers.
      Nov 2007
      I'd be just as much or more worried about the front at the rear.
      SPRING FLING XXV
      April 16 & 17, 2011
      Woodley Park, Van Nuys CA
      800+ Mopars, 300+ swap, 40+midways
      Speed Festival Track Event
      5th annual, Thursday, Willow Springs, 40+ Mopars
      Track Video
      Melbourne, FL
      If you are still doing any body work and aren't looking to keep it stock you could add some fender extractors like on this car.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Jul 2009
      Grand Rapids, MI
      My plan is to mock it up in cardboard, use the cardboard as a template, bend it out of sheet and weld it to the trunk. I've seen a few different ways of doing it and am not set on this particular way of building it. For now I was just mocking up for the look and now will work on the construction design. I like the fiberglass idea but may want something that is part of the trunk lid. Options are open though. I like your idea and will keep an eye on this thread.
      Will Ellis
      Build Thread
      Jan 2010
      Elk River, MN
      If you use urethane foam you can lay glass right on it, then hollow it out, or just keep the foam for structural rigidity. You can also finish your prototype as a plug, then make a mold from it so that you can reproduce the spoiler in fiberglass, or even carbon fiber. This is the most time-consuming method, but it's the best way to get a high-quality, lightweight part.
