Results 1 to 20 of 231
01-14-2010 #1
Project Kryptonite (Rupp Take Note)
I would like to introduce a project I have been working on for the last 4 weeks. This is a customer build and my first paying job so really excited and happy that I was able to find the perfect customer to make my debut.
Normally I do not name my cars but felt it was due for this build. I chose the name Kryptonite for 2 reasons, One is that it will be green and the second is that Superman David Pozzi and Penny better beware
This is your basic 69 Camaro Pro touring build,
DSE Front Subframe with Remote Reservoir shocks
DSE Quadra Link Rear with Remote Reservoir shocks and sway bar
DSE Mini Tubs
DSE Cross Member
DSE Closeout panel
ZO6 Brakes Front and Rear with DBA rotors and Hawk Pads
LS7 with Trick Flow 235 heads, Fast Intake and big cam
DSE Stainless Tank
Built T56 feeding a 9 inch rear
Rushforth Super Spoke 18X10 front and 18X12 rear
PS2 275/35 and 335/30 tires
CF Hood, Header panel, Cowl, Trunk lid and Spoiler from Anvil
All new sheet metal
Custom Rear tail panel
Fesler Hood Hinges
Fesler Taillights
Marqez front Valance
Full RS grill and DSE conversion
Trunk Floor replaced to run 67 Fuel Tank
Billet Fuel filler from Ride Tech
Custom Full Sheet metal dash with DSE insert
Full Chrome Moly cage with front snout bars
Custom leather interior
Vintage Air Gen IV
Flush Mount Glass from Classic auto glass innovations
Smoked side glass to match rear tint
Narrowed and Tucked front and rear bumpers
The car will be painted Grenade Green with some sort of stripe up top exposing the CF.
The plan is to debut the Car at the Face Off in the Flatlands event so will be a fast paced build.
It is a good thing I work better under pressure as the car I started with should have been crushed due to how bad the rot was.
Here are some early shots after I started back on 12/18.Brian Finch
Pro-touring Hero
The Proof is on the Pavement
Sponsored by Baer Brakes, JRI Shocks, Pennzoil, Tremec, Magnaflow, Centerforce, AFCO Racing, Kurt Urban Performance, Amercian Powertrain, Forgeline, Holley, and of course BFG.
For the best engine money can buy please visit http://www.kurturbanperformance.com/
Authorized dealer for Baer, Ridetech, Detroit Speed, Vintage Air, Motorstate Distributing, Wilwood Engineering, American Autowire, Forgeline, Holley, Afco,
Contact brian@finchperformance for special Pro-Touring.com member pricing
www.hotrodtransformations.com
01-14-2010 #2
First order of business was to start cutting out the bad and replacing metal.
I started with the quarters and outer wheel wellsBrian Finch
Pro-touring Hero
01-14-2010 #3
Next I peeled the Roof and completed the repairs to the window lip and upper front corners that were ate away from years of living under a vinyl top.
Brian Finch
Pro-touring Hero
01-14-2010 #4
On goes the new roof and off with the tail panel ending week 1
Brian Finch
Pro-touring Hero
01-14-2010 #5
The tail panel received several mods. I welded in the fuel opening from a 67 donor panel as well as a custom insert the customer picked up from a truck tail panel. Once installed I cut in openings for the Exhaust
Brian Finch
Pro-touring Hero
01-14-2010 #6
Next I moved to the firewall cutting out the entire panel someone had scabbed in some time back. I replaced it with a single piece of 16 ga and also installed new toe kick panels to complete the entire floor replacement. I rolled a new transition to the firewall and fabbed up a new upper tunnel to give the clearance needed for the 6 speed.
Brian Finch
Pro-touring Hero
01-14-2010 #7
At this point I was waiting on new door assemblies as the original doors were wasted and had been covered up with gallons of mud. So I started roughing in the main tub starting with short strand then a skim coat of Rage gold. End of week 2
Brian Finch
Pro-touring Hero
01-14-2010 #8Dave
68 Corvair coupe
65 Impala SS
64 Corvair Rampside
62 Corvair Greenbrier
Asst. daily drivers
http://www.sourceboards.com/
01-14-2010 #9
I had to go out of town for work so lost a week. When I got back the Doors, fenders and all the CF parts were waiting for me. This last week was spent hanging, pulling, welding, grinding, and cussing until all the gaps came in. I fit the Anvil parts and all the metal work is now done. End of week 3 and now we are current.
Brian Finch
Pro-touring Hero
01-14-2010 #10Starting today I will begin roughing in the body work on the doors and fenders. I plan to get it into Epoxy tommorrow or Saturday and start blocking the car out.
Also the Engine and Trans is all assembled and ready to drop in, The front and rear suspension is done and just needs final install, the cage is complete and I only need to bend the snout bars once everything is together, and the dash is all welded in and only needs a little mud to get it ready for paint.
I really need to find some talented friends close by as the 1 man show is tough.Brian Finch
Pro-touring Hero
01-14-2010 #11Brian, awesome build so far! Can you work on my car for 2 weeks to get it to this state?!? j/k!!
Ron
69 Camaro Redfire, thanks to
Marquez Design | Ring Brothers
01-14-2010 #12
