    Page 1 of 10 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 231
      Aug 2006
      Nashville TN
      Project Kryptonite (Rupp Take Note)
      I would like to introduce a project I have been working on for the last 4 weeks. This is a customer build and my first paying job so really excited and happy that I was able to find the perfect customer to make my debut.
      Normally I do not name my cars but felt it was due for this build. I chose the name Kryptonite for 2 reasons, One is that it will be green and the second is that Superman David Pozzi and Penny better beware
      This is your basic 69 Camaro Pro touring build,
      DSE Front Subframe with Remote Reservoir shocks
      DSE Quadra Link Rear with Remote Reservoir shocks and sway bar
      DSE Mini Tubs
      DSE Cross Member
      DSE Closeout panel
      ZO6 Brakes Front and Rear with DBA rotors and Hawk Pads
      LS7 with Trick Flow 235 heads, Fast Intake and big cam
      DSE Stainless Tank
      Built T56 feeding a 9 inch rear
      Rushforth Super Spoke 18X10 front and 18X12 rear
      PS2 275/35 and 335/30 tires
      CF Hood, Header panel, Cowl, Trunk lid and Spoiler from Anvil
      All new sheet metal
      Custom Rear tail panel
      Fesler Hood Hinges
      Fesler Taillights
      Marqez front Valance
      Full RS grill and DSE conversion
      Trunk Floor replaced to run 67 Fuel Tank
      Billet Fuel filler from Ride Tech
      Custom Full Sheet metal dash with DSE insert
      Full Chrome Moly cage with front snout bars
      Custom leather interior
      Vintage Air Gen IV
      Flush Mount Glass from Classic auto glass innovations
      Smoked side glass to match rear tint
      Narrowed and Tucked front and rear bumpers
      The car will be painted Grenade Green with some sort of stripe up top exposing the CF.
      The plan is to debut the Car at the Face Off in the Flatlands event so will be a fast paced build.
      It is a good thing I work better under pressure as the car I started with should have been crushed due to how bad the rot was.
      Here are some early shots after I started back on 12/18.
      Brian Finch
      Pro-touring Hero
      The Proof is on the Pavement
      Sponsored by Baer Brakes, JRI Shocks, Pennzoil, Tremec, Magnaflow, Centerforce, AFCO Racing, Kurt Urban Performance, Amercian Powertrain, Forgeline, Holley, and of course BFG.
      For the best engine money can buy please visit http://www.kurturbanperformance.com/
      Authorized dealer for Baer, Ridetech, Detroit Speed, Vintage Air, Motorstate Distributing, Wilwood Engineering, American Autowire, Forgeline, Holley, Afco,
      Contact brian@finchperformance for special Pro-Touring.com member pricing
      www.hotrodtransformations.com
      Aug 2006
      Nashville TN
      First order of business was to start cutting out the bad and replacing metal.
      I started with the quarters and outer wheel wells
      Brian Finch
      Pro-touring Hero
      Aug 2006
      Nashville TN
      Next I peeled the Roof and completed the repairs to the window lip and upper front corners that were ate away from years of living under a vinyl top.
      Brian Finch
      Pro-touring Hero
      Aug 2006
      Nashville TN
      On goes the new roof and off with the tail panel ending week 1
      Brian Finch
      Pro-touring Hero
      Aug 2006
      Nashville TN
      The tail panel received several mods. I welded in the fuel opening from a 67 donor panel as well as a custom insert the customer picked up from a truck tail panel. Once installed I cut in openings for the Exhaust
      Brian Finch
      Pro-touring Hero
      Aug 2006
      Nashville TN
      Next I moved to the firewall cutting out the entire panel someone had scabbed in some time back. I replaced it with a single piece of 16 ga and also installed new toe kick panels to complete the entire floor replacement. I rolled a new transition to the firewall and fabbed up a new upper tunnel to give the clearance needed for the 6 speed.
      Brian Finch
      Pro-touring Hero
      Jul 2007
      Calgary, Canada
      Nice looking plan and build! Good luck with the time frame.
      Quote Originally Posted by Finch View Post
      Regarding that statement, 'Get in Line!' ha ha
      Dave
      68 Corvair coupe
      65 Impala SS
      64 Corvair Rampside
      62 Corvair Greenbrier
      Asst. daily drivers
      http://www.sourceboards.com/
      May 2009
      Centennial, CO
      Looks good. One thing to consider when doing panel alignment and gaps is to put the wieght of the vehicle on the suspension.
      Pete
      "This is the worst fun I've ever had" Chad (Kel-Tec)
      Aug 2006
      Nashville TN
      Quote Originally Posted by Draginutz View Post
      The Full Cage, DSE Subframes and massive DSE cross member was all put in before starting on the metal work so the car is as stiff as can be. No worries on movement.
      Brian Finch
      Pro-touring Hero
      Jun 2006
      NW burbs IL
      Did you do all that work yourself in 3 weeks? When do you sleep? If you have a union job dont answer.
      Matt
      Brian, very cool project.
      A lot of the same items I will be using on my build as well. (When it happens!!) Thanks. Please keep us posted bud.
      Phoenix, AZ
      Chris Fesler
      Aug 2006
      Nashville TN
      Quote Originally Posted by Bow Tie 67 View Post
      This is where working from home as an IT PM pays off. I get to sneak out from time to time between meetings.
      Brian Finch
      Pro-touring Hero
      When you weld up the door gaps do you use some wire or just glob weld material on there ? Do you use MIG or TIG to do so ?
      Do you mind describing your entire process for welding up a body gap ?
      Aug 2006
      Nashville TN
      Quote Originally Posted by preston View Post
      I use a Mig to weld up the ends a stitch at a time keeping the spray bottle close to keep the heat down. On this car I had to grind away the rear lip of the doors which leaves you with 3 pieces of sheet metal to join back together. I keep my welder turned up a bit so the pentration is quick and burns into all 3 pieces. Once I have to a solid weld top to bottom I grind with a 24 grit dics to shape then grind with 80 grit DA followed up with the DA in orbital mode. I did both rear door gaps in 3 hours so does not take long
      Brian Finch
      Pro-touring Hero
      nice work so far! looks good!
      san diego
      very cool fast paced project.
      Fort Myers, FL
      Good luck on the build time, looks like your moving quick so far. As far as taking on the Pozzi's and Bad Penny Good luck your going to need it
      Chris Smock aka Blazed67
      USA
      Wow Brian ..
      That's cool.
      That looks like what my car will look like when I re-do it ...LOL..
      It's a similar build ,to what I eventually want .
      LS7's rule !!
      Are you gonna' use dry sump or wet sump ?
      Jeff Tate
      U.S.A.
      Aug 2006
      Nashville TN
      Quote Originally Posted by JEFFTATE View Post
      Wow Brian ..
      That's cool.
      LS7's rule !!
      Wet with a remote oil cooler to keep it simple
      Brian Finch
      Pro-touring Hero
