      G.R. MI
      396 tuning advice
      Alright, I have a 396 with a holley 4150 double pumper, hooker comp headers, flowmaster 40 restrictionless 2 1/2" exhaust, and had the system tuned last September. He found nearly 25% more torque by swapping jets! great!! 316 ft-lbs of torque on the ground.
      But! When I drive around town, now, it 'stutters', presumably b/c the primaries are running on the rich side for low end rpm.
      My question is, how can I remedy this? Around town and on the highway I'm <3500 rpm, but I would like to keep the tuning improvements.
      1 parameter which will change is the exahaust. I'm most likely going to install a pair of bullet perfomance mufflers and H pipe which will add some back pressure. I plan on having it tuned again sometime after the install is finished.
      My current idea is to try 1 step hotter plugs for around town. If at the track, I would swap. Are there any other ideas out there? Anybody have experience with this? Hotter plugs the ticket?
      -Bill
      G.R. MI
      Talked to a carb fanatic, and according to him, good thing to pay attention to is the amount of vacuum when the engine starts choking - I have a manifold vacuum gage in the car. If the vacuum is to low (smaller number) than the power valve rating, I'll need to replace the power valve with a lower vaccum power valve.
      We'll see where this gets me.
      The carb junkie also said that I could gain a few horses by removing the choke, and thought it might benefit me to replace the secondary blocks to allow for metering...
      making any sense to anyone out there?
      -Bill
      Aug 2003
      Prescott Valley, AZ
      I have a 396 and swapped cams to a comp 292h. I couldn’t get it to idle below 1k rpm and it also had a hesitation. After much research I sent the carb (holly 4150 750) to Mark Clark in Mesa, AZ. He did a ton to it and now it’s a screamer. I’d say go in that direction. Make sure you know what cam is in it and get an idea of how much vacuum you are getting at idle – this will help you. Don’t ask me what for but I do know it will help.
      It's shake and bake!!! and i helped!
      Drewco Homes
      Nov 2004
      It sounds like the tuner jetted the carb down last Sept. If it is 'stuttering' under light-load/part-throttle conditions now and it wasn't doing this before the tune up, it may be too lean on the primary side. Go up 2 jet sizes on the primaries and see if that helps.
      If the 'stuttering' is occurring under load (pulling away from a stop light, acceleration, etc.), it may be the PV or the accelerator pump.
      Just hook up your lap top and adjust the injector pulse width according to what your wideband oxygen sensor is indicating is the A/F ratio.
      Oh...wrong forum...LOL
