Results 1 to 20 of 21
Thread: Gravity Bleed
01-11-2010 #1
- Jan 2007
- SOCAL
- 623
Gravity Bleed
So the car is up in the air, I have hoses from the bleeder to water bottles to drain. Opened everything up and I have some fluid coming out. How long should I leave all this open? I am running a full wilwood disc brake set up, 13in 6 piston fronts and 12 in 4 piston rears. I cannot seem to get all the air out. I had a friend who did this, left it open for a week and then his brakes were perfect. Any suggestion?
01-11-2010 #2A week seems a bit excessive. If the reservoir(s) go dry, you get to start all over. Buy, beg borrow or steal a Motive pressure bleeder and you can be done with it in a half an hour.
01-11-2010 #3I used gravity for days, and then a miti-vac trying to bleed my wilwoods. Must have moved a gallon of fluid thru them. Tapped on everything to dislodge the lil bubbles. yada yada yada.
Agree completely on the pressure bleeder.
Another thing I found (is your car runnning, being driven??) is I'd get a random low pedall, that would come up in a pump or two.
A friend suggested it might be caliper knockback, from the c-clip axles moving in and out. He suggested a 2 lb RVP in the rear line. I did, and my pedal has been perfect ever since.
01-11-2010 #4
