    Page 2 of 2 FirstFirst 1 2
    Results 21 to 29 of 29
    Thread: Rubbing Issues
    1. #21
      Feb 2003
      Houston, TX
      Gotta love old cars and their sloppy tolerances too. I had a set of 10" wheels with 285 tires that fit perfectly fine on an original axle and original body 69. Swapped them onto another buddy's car with original axle and original panels, and they rubbed. Neither car had been wrecked before. Chalk it up to 1969 build tolerances, sometimes.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
    2. #22
      Nov 2007
      X2, take your time.
      Quote Originally Posted by Rybar View Post
      Gav your car looks killer with the new wheels. Sorry about the 1/4 panel and wheel fitment problem.
      Ron
      69 Camaro Redfire, thanks to
      Marquez Design | Ring Brothers
    3. #23
      Aug 2009
      Napa, Ca.
      yeah, car looks great. Too bad about the craking of the paint. You'll get there. Love those Rushforth wheels!
    4. #24
      I'm sick to my stomach at the thought of your quarter panels, Gavin. I'm so sorry to hear that.
      Some good suggestions and advice here though. Nineball/ Tony's is my favorite but we only recommend taking 3mm off of the pad and that likely won't get you where you need to be.
      I'm not sure how hard it is to get a rearend narrowed there, but if it were my car, that's exactly what I'd do.
      If you must hang new quarters, you can almost certainly gain the extra clearance you need that way but I hate to see you do all that work.
      Good luck, Gavin and please keep us posted and ask any questions you might have.
      Jason
    5. #25
      Jan 2009
      I don't know if this has been mentioned but keep in mind if you go disc brakes there later (not sure if you drums now) but that may also increase your track width and compound the problem.
      car blog... updated sporadically. http://regans66.blogspot.com/
    6. #26
      Dec 2008
      When I did the rear end of my Camaro I cut out those stupid "humps" from the outer tub and welded flat sheet metal in their place. I made my wheel opening lips fairly thin to fit big tires "out" as far as possible but found that those humps would interfere. It really frees up some space when the tire rides that far up in the wheel well.
    7. #27
      australia
      Quote Originally Posted by mm065 View Post
      thats exactly what my plan is....do you have any pics of the mods ? I thought some guys had done this as i have seen plenty of cammys with low rears and tires tucked up and under. So the outer wheelhouse will be modded..Thanks for the confidence !
      Gav
      Gav
      69 camaro rs/ss clone.
    8. #28
      australia
      Quote Originally Posted by JayR View Post
      Jason, its all good my end , i love the new rims ..Its just previous mods (in the US) before i imported the car were badly done and im sure the left side wasnt pushed outward as much as it should have been.. But it wouldnt have mattered as it had skinny wheels then. So my desicion has just been moved foward to set things right ...and hey i get to change the colour !
      Gav
      Gav
    9. #29
      Quote Originally Posted by usa-69z View Post
      Gav
      Way to find the silver lining, Gav!
      Jason
