    Results 1 to 15 of 15
      Jun 2008
      Western Washington
      Project Green Dragon (95 TA)
      Hello,
      I have been an inactive member here for a while, since I have been finishing my 95 TA before jumping too far into my 69 Camaro. I have just been researching and keeping up on a lot of these builds (there are some VERY nice ones!).
      I really don't know what to call what I have done to my 95 TA, I would categorize it as Pro-Toured (but I'm not sure if that title is reserved for older muscle cars)? Any how I think it might interest some folks...
      I am a 28 year old Mechanical Engineer working for the Navy in Bremerton, WA. My father is a Hot Rod builder/Body-Man that has been doing that for 30+ years in Montana(so I get a pretty good deal on body work ). This is the first car that I actually bought myself, I have owned it for about 7-8 years. It was originally a bolt-on car then it snowballed as my knowledge and skills progressed to what you see here.
      It still has a little body work to finish on the headlights and nose, but it is close to done.
      Parts List...
      -95 Pontiac TA
      -385 ci LT4 with Lingenfelter ported LT4 heads and intake, Callies Magnum crank, I beam rods, SRP pistons, 60 lb injectors, etc
      -EFI Connections LS1 ecu conversion (no more opti spark, Coil per cylinder, and I can tune the engine with HPtuners)
      -1 3/4 to 1 7/8 stepped SS headers
      -Dual 3" merge pipe into a single 4" pipe then after the rear end splits back to dual 3" and then to dual 5" Magnaflow bullet mufflers and rolled tips (still finishing this)
      -LC-1 Wideband O2
      -Custom designed high mounted F1A Procharger with custom front mount intercooler (Should make about 650 RWHP)
      -Level II Performabuilt 4L60e tranny with a 2200 billet stall converter, B&M stealth pro-ratchet shifter
      -PST 3.5" aluminum Drive Shaft
      -Moser 9" with auburn posi
      -Full BMR tubular chassis/suspension
      -Fays 2 Watts link with custom mounts
      -AFCO coilovers front and rear with 550lb front and 200lb rear springs
      -Mini tubbed rear end
      -19x9.5 and 20x11.5 Forgeline ZX3P wheels with Gunmetal centers
      -275/30R19 and 345/25R20 Pirelli Pzero's
      -14" Wilwood BSL6 front and 14" Wilwood BSL4 rears with integral parking brake
      -Fiberglassed Dash and painted Satin Black
      -Custom Autometer Gauge cluster
      -Corbeau CR-1 black leather seats
      -6 point roll bar and Schroth racing harnesses
      -Rear seat deleted and custom subwoofer box taking its place
      -Custom Side intakes C5 corvette style and custom ram air hood
      -90mm and 60mm Hella headlights
      -Custom mixed Lime Green and Gunmetal two-tone
      I know I am missing other stuff but those are the main components of the TA.
