      Jun 2005
      Crescent City,Ca.
      Hydroboost problem
      Hope someone can help me with this,I purchased a Hydroboost Direct from Hydratech a few years ago and just now getting the car running.When I started the car it did not even reach operating temp and the PS fluid was 246 degrees.Started checking lines and there is no circulation through thru the HB unit.It just deadheads and gets hot.No dealer has any idea and no way to contact Hydratech.Does anybody have an Idea or know the part # for a off the shelf replacement? Thanks
      Like someone always says, are the lines hooked up properly? Does it do it with the brakes depressed?
      Before buying another you can take apart that one. It's all rubber gaskets and pretty easy. Can't make it worse.
      charleston, SC
      Try (615) 449-8261. I just found the number when I googled their name.
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
      Dec 2002
      MusicCity
      There IS a difference - Thank you for choosing Hydratech!
      Paul M. Clark
      Founder / Master Engineer
      Hydratech Braking Systems ®
      www.hydratechbraking.com
