Results 1 to 20 of 28
Thread: Garage Roof Insulation Question
12-12-2009 #1
I'm sure there has to be someone who can possibly answer this
So I'm getting ready to insulate my garage and do some wall boarding.
The wall I know what to do but its the ceiling.
I know I could wallboard the ceiling and do blow in or roll in insulation but I actually like having the open storage space.
so my question is could I insulate up against the roof paneling?
GTO Project https://www.pro-touring.com/showthre...-The-Great-One
Colorado Project https://www.pro-touring.com/showthre...cab-CodeRedZQ8
Check Out My YouTube Channel http://www.youtube.com/c/geedsgarage
12-12-2009 #2One of the things that you could have done is use the Techshield roof sheeting but obviously it is to late for that, but you can still use the blow in insulation and just put your plywood over that for storage. You are trying to insulate the livable space and not the attic, correct? anything that you store up there will probably fare just fine, I would suspect. Another thing to consider is the weight up there....will you be storing heavy objects? as the trusses are engineered to carry just so much weight...
Steve Martin
67 Camaro RS
66 Chevelle
12-12-2009 #3GTO Project https://www.pro-touring.com/showthre...-The-Great-One
12-12-2009 #4
