Thread: Powder coating question
10-28-2009 #1
- Mar 2009
- Southern Maryland
- 402
I have a large stock pot maybe 3 or 4 gallons. Last year I had it too full and the coil burner burnt through the epoxy or whatever it kind of coating it is exposing bare metal.
I like the pot and was wondering if the existing damaged coating could be removed and replaced with a powder coat. What do you think something like this would cost? It might just be cheaper to junk it and get a new one.
10-28-2009 #2I would be very hesitant to use normal powdercoat on anything that will see a stovetop. The coating on those pots is usually a type of porcelain or heat stable enamel finish.
-- Dan
10-28-2009 #3
- Mar 2009
- Southern Maryland
- 402
What about the ceramic coatings? I'm not sure what the coating was that's on there it is like a dark blue with some type of white or off white spec. I'm thinking it will probably find the junk pile and I will pick up another one.
10-28-2009 #4
- Oct 2009
- 70
Any product you find no matter what it is must be food grade. I don't think it's worth your while to have it recoated.
Don L
Keep the rubber side down.
10-28-2009 #5
