Thread: T-56 matting alternative
04-09-2005 #1
- Aug 2004
- Phoenix AZ
- 292
OK, we have our retainer bearing back from the machine, and will be fitting stuff together this week,
Tyler, and anyone else into T-56 stuff, Not sure if you know or not, but if wanted a push style clutch (besides doing what we are doing), Mc leod sells a hydraulic throw out bearing that fits on the t-56 bearing retainer. Heres the bad news, it costs 387.00,
But you wouldnt need a special flywheel, and youy can save money on the performance pull style stuff. Well we will keep everyone updated on our low buck ways.
Just thought youd like to know. Bob AZ.
04-12-2005 #2
- Mar 2005
- 16
Is this Throwout for the Ls1? Does it work with Fbody Master or do you need the Mcleod master?
Thanks G
04-12-2005 #3
- Aug 2004
- Phoenix AZ
- 292
Well Im not sure if GM changed the bearing retainer size after 1996, if they didnt then this throw out bearing would apply to all factory T-56, if Tyler chims in Im sure he would know, if the bearing retainer sizes changed in between years.
Originally Posted by SmooveG
As far as having to use Mcleods MC, Im not sure. I didnt check any further, due to the fact there is no hydraulic throw out bearing worth 387.00.
The difference between theirs and lets say an 80.00 Quater Master, is the inside diameter of the bearing.
If you get a sleeve made and welded on to the bearing retainer of the T-56, its something like 4 thousanths, then you can save money on replacement parts in the future.
04-12-2005 #4
