    View Poll Results: Do Readers Want This?
    Voters
    48. You may not vote on this poll
    • Yes, do this! It's about time!
      21 43.75%
    • Boring, fugetaboutit. Besides we wouldn't have anything to argue about anymore.
      13 27.08%
    • Huh? What rim size controversary are you talking about?
      3 6.25%
    • I'd love to see it, but they probably don't have the guts to do it. :-)
      11 22.92%
    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 49 of 49
    1. #41
      Sunny Florida on the Suncoast
      I go back long enough ago in the building of the Pro-touring type of car to remember when people asked why we were putting 16" Corvette rims on Camaros and Chevelles. In my opinion that anything above an 18" is the point of deminishing returns, the brakes need to get bigger to stop all the mass that moved out from the center of the wheel. The MOI is just plain physics that set the standard here, as long as you can install bigger brakes inside those giant rims that give a better stopping ability than the wheels use up with the shift in MOI then there will be a stopping improvement. Of course it will require more engine torque to get that mass that has a exponential effect on acceleration.....damn that physics again.
      Any test between all these wheels sizes would have more than one place for a flawed test. Here is just one the difference in side wall height will effect how well the tire accelerates, a taller aspect ration tire should launch better due to the cushion effect, where the shorter aspect tire will get shocked and spin. The same would be true for cornering abilities too, a short side wall will hold the ground better due to less side wall deflection but when it does let go it will give less warning when it does. Different rim diameters require a different tire pressure to get the most effective use of the tire. When we ran 15" rims with 60 series tires the tire pressure in the front would be set at 42 psi, where a 17" with 40 series used 38 psi. When you test these wheels do you use the same pressures, or do you use a varied presure to make up for the side wall flex?
      A true test for power needed to drive a wheel would not be that hard on a test stand (equipment to read it would be similar to a transmission dyno), and the numbers for acceleration would be a gauge for how much extra force is require to slow that wheel.
      Truth is that most people pick their wheel and brake size for looks and not performance.
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
    2. #42
      Quote Originally Posted by 406 Q-ship View Post
      Exactly. As wheel size goes up, sidewall typically goes down, which improves one aspect (corner grip), but only to a point where it becomes harder to disqinguish the limits, possibly making it harder to drive at the limit. It may also make it harder to power out of a corner because less flex limits how much power the tire can handle without breaking loose. Then there's the MOI affected issues.
    3. #43
      Quote Originally Posted by treed_cutlass View Post
      In your industry how was moment of inertia tested for?
      Was it based on measurements plugged into formulas or were the objects in question installed on a spindle and spun while testing for load?
      Or some other method?
      My bad on poor terminology. We did not test MOI, we tested auto HVAC components. What I was trying to do was point out that single pass testing on volume production parts is considered unreliable. Multiple usits are tested, and if there s a significant flyer, additional units are tested to validate the outlyer is an anommolie. Usually requires an investigation into the reason the anomaly was present, and some countermeasure.
      I consider a single pass on a drag strip equally unreliable. The only way to evaluate a change (particularly where there is human control) is to run a number of tests with the same setup.
      I'm thinking the easiest way to compare MOI for a wheel/tire/brake package would be an indirect measurement. Set up an electric motor drive you could load the components on. Start from zero rpm until motor running speed is attained (I think most A/C synchronous motors is 1728 rpm). Measure voltge, current, and time to motor rpm, you can plot HP required. You can back into MOI from that.
      The other method is to calculate the MOI. Easy for a simple profile like a brake hat, not so easy for a complex shape like a wheel, and a tire where the tread surface is thicker than sidewalls, also difficult.
      All this being said, I think the MOI of the wheel/tire/brake is a small fraction of the performance braking and acceleration equation.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
    4. #44
      Separate direction from prior post.
      I went from 15's to 17's on the Camaro. Doubt I wil go larger. Since I have 17's anyway, I did chose to take advantage of larger brakes.
      Why did I increase? its the direction performance tires are headed. There ARE still good 13", 15" tires, but these are declining. If everyone goes to 17" + wheels for performance cars, why would a manufacturer continue to build 16" - performance tire? Volume doesn't justify it. Sidewall reduction also generally reduces load capacity of a tire (I was told by a Gooodyear engineer that the volume of air in a tire is related to the load capacity of the tire) and tend to decrease ride quality. There's a reason we don't just vulcanize the rubber directly to the wheel.
      I personally hope the insanity ends at 17". There is a limit to the need for bigger brakes. No way an autocross requires 13" rotors, and most wheel to wheel track racing can get away with 12" rotors. If there is a fade problem, go to better pad and rotor compounds. It's what the real racers do.
      Greg Fast
      1984 el Camino
    5. #45
      Belle Plaine, MN
      I'd be more into it with some kitsch.
      Test 15-inch Rally wheels with BFG T/As- These are still immensely popular, and have been since like 1983. Sad, but you know I'm right.
      Test 17-inch 'P/T' wheels (like Fikses or Kinesis') with Nitto/Yokohama/Kumho street tires.
      Test 19-inch 'ghetto' wheels (spinners preferred) with whatever tires those guys typically run.
      It would be more comedy than anything...but I bet people would read it!
      Scott Parkhurst
    6. #46
      Sep 2002
      San Jose, CA
      Road & Track does this test every year
      Just call me Brett
    7. #47
      SoCal
      Quote Originally Posted by Scott Parkhurst View Post
      Eh, that doesn't even really need a test. For the first two, just compare my Trans Am to Mary Pozzi's Camaro . . .
      and the last one would just be funny to watch.
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
    8. #48
      May 2009
      That helps, thanks for the clarification.
      Testing just the wheel (or wheel + tire) would be what I'm interested in, not an on-car test (as you say, too many variables), I was only interested in the properties of the wheel (or wheel + tire) itself as a tool for judging what impact it would have on pos./neg. acceleration, without considering what effect on traction the sidewall/other factors have.
      I guess for the time being we're stuck with just weighing them and taking diameter into account to get a rudimentary idea.
      Thanks for the info + comments, Greg!
    9. #49
      Jun 2005
      Funny enough.... I would think that These guys would have a LOT of data to back up their reasoning for running the size rim/tires/brakes that they do.
      Sure they may have a wheel size limitation in the rule book (I haven't looked honestly) but that's for good reason.
