    View Poll Results: Do Readers Want This?
    Voters
    48. You may not vote on this poll
    • Yes, do this! It's about time!
      21 43.75%
    • Boring, fugetaboutit. Besides we wouldn't have anything to argue about anymore.
      13 27.08%
    • Huh? What rim size controversary are you talking about?
      3 6.25%
    • I'd love to see it, but they probably don't have the guts to do it. :-)
      11 22.92%
    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 49
      Mag Editors - Who will step up?
      So we've argued to death about wheel size and it's affect. Let's put it to the test. I think this would make a great article.
      First, get a car that has brakes which allow a 15" wheel size and has the suspension already upgraded. It should be balanced so that it can run with all four corners being the same.
      Purchase the same wheel configuration (aluminum would be best to represent what most people have) in 15", 16", 17", 18", and 20". Same width and offset for each.
      Now buy tires to match with similar width that match overall tire height as closely as possible. (245 series would probably work). So for example, a 245/50R16 would be tested as well as a 245/45R17, 245/40R18, etc. The tires should be the same brand and type. No mix and match. Alignment settings should remain the same and be double checked between rim/tire changes.
      The criteria should emulate all aspects of performance. The time to 60mph would give an understanding of off-line traction, while the 1/4 mile and stopping difference would show the effect of moment of inertia. I would also recommend plotting 1/4 and stopping vs. MOM to see if there is a correlation.
      For reference, I would use the MotorTrend method of evaluating cars. www.motortrend.com/features/performance/112_0910_2009_best_drivers_car/judging_criteria.html
      This comprehensive testing puts objective numbers to things like how balanced the car is, and how quickly the vehicle responds to driver input, etc. Just doing slalom and skidpad doen't cut it anymore.
      Here's the relevant testing that would apply to rim/tire size:
      ACCELERATION
      • Time to 60 mph
      • Time to quarter mile
      BRAKING
      • 60-0-mph stopping distance
      HANDLING
      • Steering sensitivity on-center
      • Steering gain
      • Understeer
      • Maximum lateral acceleration
      • Steering angle at 0.5 g
      • Steering effort
      • Steering-response time to 0.5 g
      RIDE
      • Ride quality
      LAPPING
      • Figure-eight time
      As a final test, put weights on the 15" rims to simulate the MOM of the 20" and rerun the testing. This would show how much is related to MOM versus other factors like sidewall stiffness.
      There it is. Now let's see who has the best magazine out there.
      Jul 2003
      Anaheim Hills, CA
      But wouldn't the point of running bigger wheels be to run bigger brakes? Not many would run brakes sized for a 15-inch wheel inside an 18-inch wheel. Running the bigger brakes would yeild better braking.. running the same brakes on the 18-inch rim (for example) as the 15-inch rim would yield worse braking peformace since there's now more mass to stop.
      The only other tricky part would be finding ONE brand/style of tire that offers the same relative widths in 15,16, 17, 18, 19, and 20.
      I'm not sure I can think of one off the top of my head. the tread pattern and/or the treadwear can't change at all for this to be a valid test.
      Lasty, I think everyone knows that a bigger wheel/tire combo costs more power to move. Don't they?
      1968 Track Rat Camaro:
      10 views, no votes. WTH? If you want to see it, vote!
      Jul 2003
      Anaheim Hills, CA
      And why does this always come down to "they don't have the guts to do this?
      Really?
      Quote Originally Posted by Steve1968LS2 View Post
      But would the point of running bigger wheels be to run bigger brakes. Not many would run brakes sized for a 15-inch wheel inside an 18-inch wheel.
      I've seen alot of people run drums with 18". The point anyway is not the brake size, but to quantify the effects of rim/tire on all aspects of performance. Yes we know some things are worse for sure, but how much worse? I've seen lots of logical theory and speculation, but no real data. Do the costs in one area outweigh the benefit? Is there a point of diminishing returns?
      Not many would have all the sized available, but at least one company should.
      Really?
      It's not an easy task. Figured aiming at the ego might help.
      Hopefully someone will pick this one up. It's a long time coming.
      I guess we'll put you down for choice one instead of four. ;-)
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by 68Formula View Post
      I would say that a guy running 18-inch wheels on drum brakes cares more about "looks" and less about performance.
      I would think we could solve most of this with good old math. Running larger wheels (what is large these days?) is game of compromises. In some cases there's a performance gain to be had and in some cases it's a performance loss. I guess each person balances thier desire for performance versus thier need for asthetics.
      I would say there is a point of deminishing returns.. but where it is depends on the equipment involved. A car on 19's might performer better than a car on 17's if those 19's contain ZR1 brakes that won't fit in a smaller wheel. A car on 15's with stock drums might out stop a guy on 20s with low end disc brakes.
      I like the idea of the test, but again, which tire would "we" use that covers enough sizes?
      SoCal
      Kumho Ecsta ASX is available in 245 for wheels from 16-20".
      http://www.tirerack.com/tires/Sizes....num=445WR0EASX
      BFG G-Force Sports come in 245 for 15-18" wheels. That should be enough to make a trend on a graph. If someone actually wants 20's, they have other issues.
      I can't help but think how expensive this test would be. 4-5 sets of 4 tires at 100-160ish per tire plus the matching wheels to mount them all is going to cost a substantial amount. I suppose if a really popular wheel, like a TTII, was chosen then they could be resold without too much trouble.
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
      Well looks like 15" would be out. They've discontinued a lot of choices. But 16 thru 20" could be done. This would also mean a little larger than stock brakes could be used. Here's one that can hit all sizes in a 245 and about 26" tall.
      http://www.tirerack.com/tires/Spec.j...omCompare1=yes
      Here's some others, although the overall tire height might be a little different and you can get 4 out of 5 size between 16" and 20."
      It can be done!
      Quote Originally Posted by 79-TA View Post
      It would take some wheel and tire sponsers no doubt. But imagine the fun some of our editors could have tearing up the track all in the name of science!
      Wonder if PHRs Old Project has had it's brakes updated already...
      Henderson,NV
      This has already been argued about for about 15 pages in another thread. You run wheels just big enough to clear your brakes, end of story. From a racing aspect.
      Todd
      Quote Originally Posted by Vegas69 View Post
      Seen the posts. Haven't seen any data to back it up.
      Besides there is a lot more understanding to be gained than just accel and decel due to mass. We can quantify
      How much straight line traction do I give up by going shorter sidewall?
      At what point does the sidewall get so short, that handling at the limit becomes unpredictable?
      Is there a tradeoff betwen going so short that I can't power out of a curve as fast, but I can go into it deeper and make up the time?
      How much accel do I give up (excluding traction) as I go from a 16" up to a 20"?
      How much decel do I give up necessitating going to the next brake size?
      Am I going to really notice the ride difference between a 17" and 20" rim?
      And more!
      Somethings (but not all) might be obvious looking at the extremes but plotting the results to quantitative values could give some interested trends to consider when determining your next size.
      Jun 2006
      NW burbs IL
      Honestly this is nit-picking. The performance difference most likely counld not be validated. Buy what you like then learn how to drive. When your driving can eek out any performance benefit from any differences start applying for a professional drivers position.
      Matt
      Cumberland, Maryland
      Can we take this another direction? Such as when do we stop adding to the size of the brakes? Is there any reason we can't build a 12" brake system that will lock up the tires even on 18" wheels and big sticky tires? Once the tires are locked up the brakes are no longer the limiting factor correct?
      I know over on the thirdgen f-body forum there was a guy who custom built a set of 6 piston wilwoods that fit under 16" iroc wheels, and later on a guy built a set set of 4 piston wilwoods to fit under 16" GTA wheels.
      SCCA AS (pony car) class limits their brakes to 12.2" (i think) rotor size and these cars are probably driven harder and deeper to any of our daily drivers, repetitively. Now before you tell me these car are light race car, I'm fairly certain minimum weight is still above 3k lbs.
      I understand that a larger rotor is a larger heat sink and should withstand multiple stops for a larger period of time than a smaller rotor. When is the larger rotor and added unsprung weight necessary?
      Aug 2006
      Nashville TN
      I would have voted but "Who gives a sh*t" or "Quit wasting time on non value add discussions and get back to work on your ride" was not one of the options.
      The mag editors need to run tech stories on topics most people have interest in. For 99% of the people out there buying wheels it is about looks and cost.
      Brian Finch
      Pro-touring Hero
      The Proof is on the Pavement
      Sponsored by Baer Brakes, JRI Shocks, Pennzoil, Tremec, Magnaflow, Centerforce, AFCO Racing, Kurt Urban Performance, Amercian Powertrain, Forgeline, Holley, and of course BFG.
      For the best engine money can buy please visit http://www.kurturbanperformance.com/
      Authorized dealer for Baer, Ridetech, Detroit Speed, Vintage Air, Motorstate Distributing, Wilwood Engineering, American Autowire, Forgeline, Holley, Afco,
      Contact brian@finchperformance for special Pro-Touring.com member pricing
      www.hotrodtransformations.com
      Easy to remember rule of thumb (this comes from Mazda Racing): each inch of wheel equals about 50 lbs of weight. The difference between a 18" wheel and a 20" wheel is about the same as adding 100 lbs to the weight of the car. That's per wheel.
      jp
      ​John Parsons
      Here's one person's test with 17" vs 18" wheels:
      Debate is going on about how much getting 18 inch wheels will effect the 1/4 mile time.
      What I have data on is 18's with shorter tires compared to the stock 17's. (225/40/18 Vs 215/50/17) This tire size is the most common in a wheel/tire package.
      The approximate difference for the 18's is about 7 mm (0.3'') shorter; which in turn, topping out in 3ird, it will be 93.5mph instead of 95mph (which does hurt).
      The weights (which I haven't weighed yet) are very close between them (within 2 lbs).
      Each best run was done with very similar conditions - ~75 degrees and decent humidity.
      Best time with stocks:
      60' - 2.281
      330- 6.277
      1/8- 9.557 @ 74.91
      1000 12.375
      1/4- 14.750 @ 94.94
      Best time with 18's:
      60' - 2.291
      330- 6.384
      1/8- 9.677 @ 74.49
      1000 N/A
      1/4- 14.929 @ 93.15
      Difference:
      60' - (+.010) - Barely enough to be a difference
      330- (+.107) - 2ond gear shift possibly slower, but not bad.
      1/8- (+.120) - kept around the same split.
      1/8- (+.42MPH) - lost MPH, not good, wheels dragging the engine a bit, even though the tires are shorter - i.e. better gearing.
      1000- I really wanted this data, oh well
      1/4- (+.179) - Lost more time, and there is no gear change between the 1/8 and the 1/4.
      1/4- (+1.79MPH) - The big one, Lost almost 2 mph, and I didn't hit the rev limiter until AFTER the traps. This means the 18's are definitely more effort for the engine, even with tires that might make up the difference.
      ​John Parsons
      Jun 2006
      NW burbs IL
      Good info, I'm glad I hate anything over 18"
      Matt
      Newbury Park, CA
      Guts has noththing to do with it. There's a practical limitation to a one-size-fits-all test. Optimal results can only be found by testing on the vehicle in question. What works on one car may not work at all on another.
      Indiana
      ANY test [and I personally know of no exceptions in the real world] is going to be subject to variation. It will always be up to the interpreter of the data to determine how the results pertain to their situation and to what extent.
      In english...if you are looking for some sort of definitive answer to these questions...you will likely be disappointed.
      I don't think that it is an issue of the magazines not having the guts [they do], or manufacturers being afraid of the results [doubt that one too]. I think it is simply a matter truly determining a relevant goal that is actually quantifiable instead of mostly subjective and open to [mistaken] interpretation.
      Think about how many drag races are won with engines that produced less power on the dyno that their competition.
      Having said all that...it might still be nice to ATTEMPT a test like this...
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
