    Results 1 to 11 of 11
      May 2002
      Southeastern WI
      Manual clutch with LS?
      Does anyone make a product that would adapt a manual clutch shaft pivot ball to an LS engine? We are getting ready to convert my dad's 68 to an L92 this Thanksgiving. He is old school and would rather keep the manual clutch linkage because that is what he knows how to work on.
      Jeff
      I think there is a company that makes a bracket that bolts to the bellhousing that will allow you to retain the pivot location on the engine for the z-bar. For what its worth, the hydraulic setup works very nice, but I understand your Dad may not want to deal with it.
      May 2002
      Southeastern WI
      Once more. Does anyone know if or where I can find something like this?
      Jeff
      Quote Originally Posted by Van B View Post
      Give Lakewood a call. Looks like their PN 15005 might be it.
      http://www.lakewoodindustries.com/pd...llhousings.pdf
      May 2002
      Southeastern WI
      Thanks Andrew. I'll have pops call them tomorrow.
      Jeff
      Dec 2007
      British Columbia, Canada
      Jeff I have that same bellhousing for LS swap, but am using a hydraulic set up. It does have the bracket to bolt the linkage up to it. If you want, I can take some pics tomorrow and post them for you. I'm at work right now so can't do it until then.
      Houston, Tx
      I would recommend the hydraulics... I put them in my car and the clutch feel is awesome once you get it bled.
      I bled the McLeod master using the tick performance speed bleed line in under 20 minutes in a dry system. It feels excellent!
      Dec 2007
      Here's a picture of the linkage bracket on the Lakewood LS housing. It was taken with my cell phone when I got home this morning. If you want a better pic, I can take one but this should give you the idea.
      May 2002
      Southeastern WI
      Quote Originally Posted by Taylor1969 View Post
      I have hydraulic in my car, but dad is stuck on manual, so that is what he will have. I think I might have found something that will work.
      http://www.sdparts.com/product/SDCB/...andTrucks.aspx
      Thanks for all of your input.
      Jeff
      The SDPC bracket should work well. Now you have to make sure that whatever engine adapter plates that will ensure that the back of the block is in the exact same position as your old engine. I found the Edelbrock plates to do just that.
      May 2002
      Southeastern WI
      Another important consideration is that the headers and engine mount adapter plates keep the headers off the steering box. We are going to order up the Hooker long tube kit from Jegs that comes with the plates and hope for the best.
      I will keep the Edelbrock pieces in mind if we run into trouble.
      Jeff
