      Aug 2008
      Tire width size help
      Does anyone know how wide and tall is a 305/35 22 series tire on a 22x12 rim. I am looking to run this on a 71 442. I know that I will have to make new wheel tubs, But I am unsure if it will fit in the factory frame rails with the new tubs. For the front I plan on running a 235/35 20. thanks
      Dec 2008
      Lehigh Valley Pa
      Quote Originally Posted by 71 pro olds View Post
      It is 12 inches wide 30.4 inches tall. The front is 10 inches wide and 27 inches tall. I use this and it has helped a ton.
      http://www.rims-n-tires.com/rt_specs.jsp?postId=906
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      Jul 2009
      Why dont you go with a 315/25/22 instead.Here are some on my SS with 22x11 rims
      Aug 2008
      A 25 series tire is too small for what I need. My motor is a 632 merlin and if needed I will back half the car, so custom wheel tubs is a must. The rear is being shortened 4 inches. Really would like a 40 series or bigger and atleast a 14 inch wide tire. Still need to research what is available for tires out there.
